Arduino Mega 2560 and Eclipse
I bought an Arduino Mega 2560 and am trying to use eclipse to build and upload my code. I already used eclipse on my 168 with no problems, witch was configured using the tutorial on the Arduino page.
To make eclipse work with the Meta2560 I've changed "Target Hardware" to "ATmega2560". The programmer configuration is more dificult. According to boards.txt the programmer should be stk500v2 and the baud rate 115200bps. In this way I get:
C:\WinAVR-20100110\bin\avrdude -pm2560 -cstk500v2 -Pcom29 -b115200 -V -D -Uflash:w:arduinotest.hex:a
avrdude: stk500_2_ReceiveMessage(): timeout
I've already tried a lot of combinations of cstk500v2, cstk500v1, cstk500, arduino and cstk200 with baud rates of 19200, 57600 and 115200 and got timeouts or sync errors. For example:
C:\WinAVR-20100110\bin\avrdude -pm2560 -cstk500v1 -Pcom29 -b115200 -V -D -Uflash:w:arduinotest.hex:a
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done.  Thank you.
make: *** [avrdudedummy] Error 1
So, the question is simply: how can I use avrdude to upload my firmware into my Arduino Mega 2560?
ps: It works fine with the Arduino IDE.
I can't remember if it's necessary but all my examples use it...
C:\WinAVR-20100110\bin\avrdude -pm2560 -cstk500v2 -P[glow]\\.\[/glow]com29 -b115200 -V -D -Uflash:w:arduinotest.hex:a
The programmer should work as Arduino. This is what I have for the 328 and 1280. I don't see why the 2560 should be any different:
No effect.
Applying the changes by Coding Badly and Andy Brown (thank you)
C:\WinAVR-20100110\bin\avrdude -pm2560 -carduino -P//./COM29 -b57600 -V -D -Uflash:w:arduinotest.hex:a
avrdude: stk500_getsync(): not in sync: resp=0xfc
Changing to 115200 bps (that seams to be the baud rate used by Arduino IDE on this board):
C:\WinAVR-20100110\bin\avrdude -pm2560 -carduino -P//./COM29 -b115200 -V -D -Uflash:w:arduinotest.hex:a
avrdude: stk500_getsync(): not in sync: resp=0xe0
Unfortunately the "//./" before the port name don't seams to have effect.
I've tried also all combinations of arduino, stk500, stk500v1 and stk500v2 with 57600 bps and 115200 bps, without success. Any glue?
You might want to try with the other slashes.
I'm very sorry for taking so long time to answer. I had to finish the project using the Arduino IDE. :\
Returning to the problem, the change from "//./" to "\.\" makes no diference on the errors. But I've discovered by accident a few minutes ago that if I fire the following commands in sequence the first fail and the second succeeds:
avrdude.exe -pm2560 -carduino -P\\.\COM20 -b115200 -V -D -Uflash:w:arduinotest.hex:a
avrdude.exe -pm2560 -cstk500v2 -P\\.\COM20 -b115200 -V -D -Uflash:w:arduinotest.hex:a
The execution goes like:
$ avrdude.exe -pm2560 -carduino -P\\.\COM20 -b115200 -V -D -Uflash:w:arduinotest.hex:a
avrdude.exe: stk500_getsync(): not in sync: resp=0xe0
avrdude.exe done.  Thank you.
$ avrdude.exe -pm2560 -cstk500v2 -P\\.\COM20 -b115200 -V -D -Uflash:w:arduinotest.hex:a
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.07s
avrdude.exe: Device signature = 0x1e9801
avrdude.exe: reading input file "arduinotest.hex"
avrdude.exe: input file arduinotest.hex auto detected as Intel Hex
avrdude.exe: writing flash (18254 bytes):
Writing | ################################################## | 100% 4.02s
avrdude.exe: 18254 bytes of flash written
avrdude.exe: safemode: Fuses OK
They must be fired in sequence without waiting between them, of the second command will fail like:
avrdude.exe: stk500_2_ReceiveMessage(): timeout
and repeat the timeout line endlessly.
I'll try to add the first line on the build chain on eclipse to see if it works, but I'm quite confident it will. Some idea about how to solve the problem with a more... say 'elegant' approach?
