Arduino mega 2560 avrdude stk500v2_receivemessage() timeout on mac Big Sur
I can't upload any code to mega 2560. there is no extra circuit attached. I am trying to upload Blink from examples and still didn't work. and I did try on another laptop running Linux it works smoothly. so I think there is nothing wrong with the hardware.
I am running the latest version of Arduino IDE 1.8.13, and updated Arduino AVR Boards from Boards Manager. and also tried many times to install and reinstall the Arduino IDE.
the mysterious thing is that it works fine a few days ago, I really have no idea what would be the problem and how can I fix this.
any help would be appreciated!
I am having a similar problem. Same board… although mine is in a HIPTOP Duale 3 3d Printer. I installed the wrong firmware using Cura and now I have two lines of boxes across the display and cannot get IDE to connect…
/* -*- c++ -*- */
    Reprap firmware based on Sprinter and grbl.
 Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
 This program is free software: you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation, either version 3 of the License, or
 (at your option) any later version.
 This program is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License for more details.
 You should have received a copy of the GNU General Public License
 along with this program.  If not, see <http://www.gnu.org/licenses/>.
 This firmware is a mashup between Sprinter and grbl.
  (https://github.com/kliment/Sprinter)
  (https://github.com/simen/grbl/tree)
 It has preliminary support for Matthew Roberts advance algorithm
    http://reprap.org/pipermail/reprap-dev/2011-May/003323.html
/* All the implementation is done in *.cpp files to get better compatibility with avr-gcc without the Arduino IDE */
/* Use this file to help the Arduino IDE find which Arduino libraries are needed and to keep documentation on GCode */
#include "Configuration.h"
#include "pins.h"
#ifdef ULTRA_LCD
  #if defined(LCD_I2C_TYPE_PCF8575)
    #include <Wire.h>
  #elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008)
    #include <Wire.h>
    #include <LiquidTWI2.h>
  #elif defined(DOGLCD)
    #include <U8glib.h> // library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/)
  #else
    #include <LiquidCrystal.h> // library for character LCD
  #endif
#endif
#if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
#include <SPI.h>
#endif
#if defined(DIGIPOT_I2C)
  #include <Wire.h>
#endif
Here’s the error message:
Arduino: 1.8.13 (Windows 10), Board: “Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)”
java.io.IOException: The sketch already contains a file named “Marlin.ino”
at processing.app.Sketch.checkNewFilename(Sketch.java:273)
at processing.app.SketchFile.renameTo(SketchFile.java:179)
at processing.app.SketchController.save(SketchController.java:347)
at processing.app.Editor.handleSave2(Editor.java:1908)
at processing.app.Editor.handleSave(Editor.java:1883)
at processing.app.Editor.handleExport(Editor.java:2023)
at processing.app.EditorToolbar.handleSelectionPressed(EditorToolbar.java:498)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:448)
at java.awt.Component.processMouseEvent(Component.java:6536)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4532)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Sketch uses 93750 bytes (36%) of program storage space. Maximum is 253952 bytes.
Global variables use 4073 bytes (49%) of dynamic memory, leaving 4119 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM5 -b115200 -D -Uflash:w:C:\Users\CRISPY~1\AppData\Local\Temp\arduino_build_657716/Marlin.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM5
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error occurred while uploading the sketch
“Show verbose output during compilation”
option enabled in File → Preferences.
Do I need to buy a new board or can this be fixed?
thx!
UPDATE: Purchased 2 arduino mega2560's (I know I only need one, but I'm getting the exact same results with either one) and have been trying to learn how any of this stuff works. My board has an ATmega2560 processor and another processor to manage the usb connection. 2 ICSP ports. So I wire the Arduino Mega2560 to the board and I have checked the wiring multiple times. Added the capacitor. Power on the board and plug the usb into the arduino. Everything has the correct lights. I had already installed the ArduinoISP to the arduino. I even went back to IDE version 1.6.3 without success. Although the output was a little different.
So I have the programmer as Arduino as ISP and the port and board settings are correct. When I try to burn the bootloader I get
/Arduino: 1.6.3 (Windows 8.1), Board: "Arduino Mega ADK"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Mar 30 2015 at 14:56:06
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions./
When I try it with IDE version 1.8.3 I get timeout errors or device ID errors with 00x000000....
Oh.. and I've tried a few different sketches and that has not made any difference.
I just ordered a programmer so I'm going to try that next. Any suggestions would be greatly appreciated!
