I have the following code which was written in Arduino mega 2560, but I don't know how to convert it to run in Arduino Uno. Can anyone tell me what needs to be changed?
printer_driver.ino (7.82 KB)
so, what should I change in that line?
The xaar128 header makes provision for the Uno so it's possible. Have you looked at this?
#include "Arduino.h"
//#include "carriage.h"
#include "xaar128.h"
int PENDING = 200;
int CYCLES = 1;
Xaar128 xaar128;
void setup (void) {
//Carriage carriage;
xaar128.init();
// Set up a 1mHZ square wave for Xaar state machine CLK.
// http://forum.arduino.cc/index.php?topic=103370.0
TCCR1A = _BV(COM1A0); // toggle OC1A on compare match
OCR1A = 7; // top value for counter
// UNO //TCCR1B = _BV(WGM12) | _BV(CS10); // CTC mode, prescaler clock/1
Serial.print("Begin: ");
Serial.println(PENDING);
float steps = 0.0;
float fails = 0.0;
//carriage.init(LOW);
xaar128.powerUp();
for (int c=0; c<CYCLES; c++) {
for (int p=0; p < PENDING; p++) {
xaar128.loadData(p);
delayMicroseconds(1);
if (!xaar128.fire()) fails++;
//carriage.step();
steps++;
carriage.changeDir();
carriage.step();
delay(100);
xaar128.powerDown();
//carriage.shutdown();
printSummary(fails, steps);
void printSummary(float fails, float steps) {
Serial.println("Done.");
float f = fails / steps;
Serial.print("Steps: ");
Serial.print(steps);
Serial.print(" Fails: ");
Serial.print(fails);
Serial.print(" Failure Rate: ");
Serial.println(f, 4);
void loop (void) {} // end of loop
Delta_G:
No, I don't know anything about that header. I just know there's got to be more to it than:If OP wants to link me to that library then maybe I'll look at it. But I'm not going to hunt it down.
Sorry DG, my statement/query was directed to the OP.
I got a Mega anyways because this is a 3D printer that we are building, and an Arduino UNO is not a good choice anyway.
shangari_jasdeep24:
If size is an issue, there ARE Mega clones that are the same size as a Uno.
