I'm using Arduino Mega 2560 board and ESP8266-01
I wanna connect my ESP8266-01 to my PHP website. I just wanna request URL like this,
"mysite.000webhost.com/index.php?out"
and I have wrote a PHP code to connect to my firebase. PHP site and firebase both are working fine.
But the problem is how can I load my URL with arduino code?
Please someone help me with this case I'm tired for find a solution with this case. ![]()
This is my code.
int ledPin = 13;Â Â Â // LED+
// int temp_sensor = A0; // LM35 Output
 pinMode(ledPin, OUTPUT); // Set ledPin as Output
 Serial.begin(9600);   // PC Arduino Serial Monitor
 Serial1.begin(115200); // Arduino to ESP01 Communication
 connectWiFi();     // To connect to Wifi
// float analog_val = analogRead(temp_sensor);Â Â // Read Analog Temperature
Â
 //j=tempc;
 digitalWrite(ledPin, HIGH); // LED ON
 delay(500);        // wait for 500 mSec
 digitalWrite(ledPin, LOW); // LED OFF
 Serial1.println("AT+CIPMUX=0\r\n");   // To Set MUX = 0
 delay(500);              // Wait for 2 sec
 // TCP connection
 String cmd = "AT+CIPSTART=\"TCP\",\""; // TCP connection with https://thingspeak.com server
// cmd += "184.106.153.149";Â Â Â Â Â Â Â Â // IP addr of api.thingspeak.com
 cmd += "mywebsite.000webhostapp.com";           // ip address of my site
 cmd += "\",80\r\n\r\n";         // Port No. = 80
 Serial1.println(cmd);          // Display above Command on PC
 Serial.println(cmd);          // Send above command to Rx1, Tx1
 delay(2000);              // Wait for 20 Sec
 if(Serial1.find("ERROR"))        // If returns error in TCP connection
  Serial.println("AT+CIPSTART error"); // Display error msg to PC
  //return;
 // prepare GET string
 String getStr = "POST /index.php?in HTTP/1.0 ";
 getStr += "Host: mywebsite.000webhostapp.com";
//Â getStr += apiKey;
//Â getStr +="&field1=";
//Â getStr += analog_val;
 getStr += "\r\n\r\n";
 Serial.println(getStr);        // Display GET String on PC
 cmd = "AT+CIPSEND=";          // send data length
 cmd += String(getStr.length());
 cmd+="\r\n";
 Serial.println(cmd);         // Display Data length on PC
 Serial1.println(cmd);         // Send Data length command to Tx1, Rx1
Â
 delay(1000);             // wait for 20sec
 if(Serial1.find(">"))          // If prompt opens //verify connection with cloud
  Serial.println("connected to Cloud"); // Display confirmation msg to PC
  Serial1.print(getStr);        // Send GET String to Rx1, Tx1
  Serial1.println("AT+CIPCLOSE\r\n");  // Send Close Connection command to Rx1, Tx1
  Serial.println("AT+CIPCLOSE");    // Display Connection closed command on PC
Â
 // thingspeak free version needs 16 sec delay between updates
// delay(1000);Â Â Â Â Â Â Â Â Â Â Â Â Â Â // wait for 16sec
boolean connectWiFi() {Â Â Â Â Â Â Â // Connect to Wifi Function
 Serial1.println("AT+CWMODE=1\r\n"); // Setting Mode = 1
 delay(100);            // wait for 100 mSec
 String cmd = "AT+CWJAP=\"";    // Connect to WiFi
 cmd += "Silver-WiFi";         // ssid_name
 cmd += "\",\"";
 cmd += "MyWifi123";        // password
 cmd += "\"\r\n";      Â
Â
 Serial.println(cmd);        // Display Connect Wifi Command on PC
 Serial1.println(cmd);       // send Connect WiFi command to Rx1, Tx1
Â
 delay(500);           // wait for 10 sec
 Serial1.println("AT+CWJAP?");   // Verify Connected WiFi
 if(Serial1.find("+CWJAP"))   Â
  Serial.println("OK, Connected to WiFi.");    // Display Confirmation msg on PC
  return true;
  Serial.println("Can not connect to the WiFi."); // Display Error msg on PC
  return false;
