Arduino Mega 2560 exit status 1
I am very new to programing and playing with Arduino. I finally got this program to have no errors on Verify. So I try uploading it to the board and I get the error below
/*Programming Logic
Assign an array of nine photo cells as follows:
0              1              2
3              4              5
6              7              8   */
int cells[9];
int b;
int now;
// read values into array and display them
void setup(void) {
  // We'll send debugging information via the Serial monitor
//int b;
void bright(void)
  for(now=0; now<9; ++now)
    b=analogRead(now);
   cells[now]= b;
   Serial.print("Analog reading = ");
   Serial.println(b);}
 // delay(100);
//this may not be all that is needed to display them?  %D maybe
// Scan all and find brightest:
b = cells[0];
for (now=1; now<9; now++)
  if( cells[now]> b) b = cells[now];
   Serial.print("brightest = ");
  Serial.println(b);
If brightest=4 then movedelay else
If brightest=1then movedr
If brightest=2 then moved
If brightest=3 then movedl
If brightest=4 then mover
If brightest=6then movel
If brightest=7 then moveur
If brightest=8 then moveu
If brightest=49then moveul end else
This is the error. I haven't had any luck with poking through the settings. Advice will be welcome. Please and thank you.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\SIMULA~1\AppData\Local\Temp\cchvSO4S.ltrans0.ltrans.o: In function `main':
cchvSO4S.ltrans0.o:(.text.startup+0x14a): undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Invalid library found in C:\Users\Simulator\Documents\Arduino\libraries\Solar_cell_test: C:\Users\Simulator\Documents\Arduino\libraries\Solar_cell_test
option enabled in File -> Preferences.
Also, if this is in the wrong area, I am sorry
Where is your loop() function?
larryd:
I said I was very new.. I shall start looking on how to make one.
See:
Right now, I just want it to run once and stop.
The board has a bunch of photocells and want it to tell me which one is the brightest.
The Right now I want to get it on the board to make sure it works.
Once I have the rest of the parts in, I will put the loop in.
My biggest problem is trying to get it onto the board
You need a loop function even if it is empty.
//this loop function is empty.
Edit
You need to 'call' bright(void) in setup() if you want to run it once.
larryd:
Edit
With that, it should be able to go onto the board?
exit status 1
Post your new code
evanmars:
Post your new code
larryd:
Edit
The loop worked.. it's on the board ^.^
:slight_smile:
larryd:
:slight_smile:
Now onto how to get it to print on screen.
