Hi, I'm using google translator apology but only speak Spanish.
I have a problem with the Arduino Mega 2560 (AT2560 16AU)
the problem is when I connect the Arduino Mega to a port (which always and connected and works corretamente, look at the silver single LED lights Power and L but the TX and RX not flashing as they always do and to compile a code out this error message ..
El Sketch usa 6.834 bytes (2%) del espacio de almacenamiento de programa. El máximo es 253.952 bytes.
Las variables Globales usan 819 bytes (9%) de la memoria dinámica, dejando 7.373 bytes para las variables locales. El máximo es 8.192 bytes.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Ha ocurrido un error mientras se enviaba el sketch
Do you have three exclaimation points in a row in a string in the program? There's a bug in old versions of the bootloader that chokes if it sees three exclamation points in a row. The bug was long since fixed, but lots of clones ship with bootloaders effected by that bug. (ex, Serial.println("Hello World!!!"); would trigger the bug. Serial.println("Hello World!!"); would not)
(note - it could be many things that are causing it, not just this. The signature of this is the upload proceeding part of the way and then choking in the middle - but you can't tell if that's what happened from looking at the error after the fact)
