Arduino mega 2560 line follower code needed - help!
Hello!
I'm noob at arduino.
I have Arduino Mega 2560 and motorshield + 3x QTR-1A Reflectance Sensor and 2 basic motors!. So, my problem is: Can someone send or make me code, which follows black line on white background. I have found some but they wont work :frowning: (something like this: Line Follower using Arduino - YouTube)
Please...
Here are the code based on sample code provided by Pololu.com
//  Based on sample code provided by Pololu.com
#include <PololuQTRSensors.h>
#include <AFMotor.h>
AF_DCMotor motor1(1, MOTOR12_8KHZ ); // PIN 11 - create motor #1 pwm
AF_DCMotor motor2(2, MOTOR12_8KHZ ); // PIN 3 - create motor #2 pwm
// Change the values below to suit your robot's motors, weight, wheel type, etc.
#define KP .2
#define KD 5
#define M1_DEFAULT_SPEED 50
#define M2_DEFAULT_SPEED 50
#define M1_MAX_SPEED 70
#define M2_MAX_SPEED 70
#define MIDDLE_SENSOR 3
#define NUM_SENSORS  5      // number of sensors used
#define TIMEOUT       2500  // waits for 2500 us for sensor outputs to go low
#define EMITTER_PIN   2     // emitter is controlled by digital pin 2
#define DEBUG 0 // set to 1 if serial debug output needed
PololuQTRSensorsRC qtrrc((unsigned char[]) {  18,17,16,15,14} ,NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
  manual_calibration();
  set_motors(0,0);
int lastError = 0;
int  last_proportional = 0;
int integral = 0;
  unsigned int sensors[5];
  int position = qtrrc.readLine(sensors);
  int error = position - 2000;
  int motorSpeed = KP * error + KD * (error - lastError);
  lastError = error;
  int leftMotorSpeed = M1_DEFAULT_SPEED + motorSpeed;
  int rightMotorSpeed = M2_DEFAULT_SPEED - motorSpeed;
  // set motor speeds using the two motor speed variables above
  set_motors(leftMotorSpeed, rightMotorSpeed);
void set_motors(int motor1speed, int motor2speed)
  if (motor1speed > M1_MAX_SPEED ) motor1speed = M1_MAX_SPEED; // limit top speed
  if (motor2speed > M2_MAX_SPEED ) motor2speed = M2_MAX_SPEED; // limit top speed
  if (motor1speed < 0) motor1speed = 0; // keep motor above 0
  if (motor2speed < 0) motor2speed = 0; // keep motor speed above 0
  motor1.setSpeed(motor1speed);     // set motor speed
  motor2.setSpeed(motor2speed);     // set motor speed
  motor1.run(FORWARD);
  motor2.run(FORWARD);
void manual_calibration() {
  int i;
  for (i = 0; i < 250; i++)  // the calibration will take a few seconds
    qtrrc.calibrate(QTR_EMITTERS_ON);
    delay(20);
  if (DEBUG) { // if true, generate sensor dats via serial output
    for (int i = 0; i < NUM_SENSORS; i++)
      Serial.print(qtrrc.calibratedMinimumOn[i]);
      Serial.print(' ');
      Serial.print(qtrrc.calibratedMaximumOn[i]);
      Serial.print(' ');
