Arduino Mega 2560 - Neo Pixel - Hanging after Setup() and before main Loop()
Hello!
I have been trying to figure out why this bit of code hangs right after the Setup() function and before it hits the main Loop ()
I believe it has to do with how I’m handling the Neo Pixel objects and something with pointers vs objects? I’m really not sure to be honest, I know enough coding to be dangerous but not functional - yet.
Any help would be greatly appreciated, below is the code I have been working with.
#define NEOPINONE 16
#define togglePinIn 15
// Number of pixels per group need to be defined before init of the strips as pixel array sizes are rquired for the strip init
int currentIndex = 0;
int NumberOfStrips = 1;
int GroupArray[] = {0,4,8}; //used to find the span of each group
int NumberOfGroups = 2;
Adafruit_NeoPixel Strip = Adafruit_NeoPixel(0, NEOPINONE, NEO_RGB); // required for color init?
Adafruit_NeoPixel StripOne = Adafruit_NeoPixel(8, NEOPINONE, NEO_RGB);
//Adafruit_NeoPixel StripTwo = Adafruit_NeoPixel(4, NEOPINONE, NEO_RGB);
uint32_t Red = Strip.Color(225, 0, 0);
uint32_t Blue = Strip.Color(0, 225, 0);
uint32_t Green = Strip.Color(0, 0, 225);
uint32_t Off = Strip.Color(0, 0, 0);
uint32_t Purple = Strip.Color(0, 120, 225);
uint32_t GlobalColor;
bool Output_Debug = true;
int Number_Of_Pins = 2;
//build and array of possible Strips to modfiy
Adafruit_NeoPixel Strips[] = {StripOne};
	Debug("Start \n");
	pinMode(togglePinIn, INPUT_PULLUP);
	for(int x = 0; x < NumberOfStrips; x++)
		Debug("NumberOfStrips index : " + String(x) + "\n");
		Adafruit_NeoPixel currentStrip = Strips[x];
		currentStrip.begin();
		currentStrip.show();
		 for(int y = 0; y < NumberOfGroups; y++)
			Debug("NumberOfGroups index : " + String(y) + "\n");
			for(int z = GroupArray[y]; z < GroupArray[y + 1]; z++)
				SetColor(currentStrip, Red, z);
				Debug("GroupArray index of : " + String(z) + "\n");
		ClearAll();
	Debug("Finished Init \n");
	Debug("Current Main Loop Index" + String(currentIndex) + "\n");
	//Adafruit_NeoPixel test = Strips[0];
	//SetColor(test, Green, currentIndex);
	//SetColor(test, Off, currentIndex == 4 ? 0 : currentIndex - 1);
	StripOne.setPixelColor(currentIndex, Green);
	StripOne.setPixelColor(currentIndex == 4 ? 4 : currentIndex - 1, Off);
	StripOne.show();
	currentIndex >= 4 ? currentIndex = 0 : currentIndex++;
void Debug(String text ) {
	if(Output_Debug)
		Serial.print(text);
void ClearAll() {
	Debug("ClearGroup Called \n");
		Adafruit_NeoPixel workingStrip = Strips[x];
			Debug("NumberOfGroups index :" + String(y) + "\n");
			ClearGroup(y, workingStrip);
void ClearGroup (int group, Adafruit_NeoPixel &strip) {
	for(int x = GroupArray[group]; x < GroupArray[group + 1]; x++)
		Debug("ClearGroup index : " + String(x) + "\n" );
		strip.setPixelColor(x, Off);
	strip.show();
void SetColor (Adafruit_NeoPixel &strip, uint32_t color, int pixel) {
	strip.setPixelColor(pixel, color);
uint32_t ColorPick(int x, Adafruit_NeoPixel strip ) {
  switch (x) {
    case 0: return strip.Color(0, 0, 0); //off, needs to be first, hold button seems to defualt to 0
    case 1: return strip.Color(0, 225, 0); //red
    case 2: return strip.Color(0, 0, 225); //blue
    case 3: return strip.Color(225, 0, 0); //green
    case 4: return strip.Color(0, 120, 225); //purple
    case 5: return colorPick(2);
You could read this to see how to declare a pointer to an instance and also read this
