Arduino Mega 2560 onboard LED not working?
Review for Rovr Rollr 60 Wheeled Cooler
There is no doubt that Yeti and Orca are familiar names when it comes to the best hard sided cooler options. But what if there is another hard sided cooler option that, although it cannot compete in terms of insulation ability, could offer you more value and therefore be the better choice overall?
OVERVIEW
If you ever wanted a wheeled cooler, do know that you have a lot of options to choose from. With varying levels of quality, there are a lot of flexible options of wheeled coolers catering to different niches. But if you would like your cooler to perform well, then our advice to you is to save up and invest in a really good model like the Rovr Rollr 60 cooler. While this is a really pricey option, the most expensive one in fact, the payoff is more than worth it.
In terms of insulation performance, this regrettably cannot compete with the likes of the Top Rated Coolers For Camping on the market like Orca or Yeti cooler models. However, its performance is still very impressive with an above average ice retention capability. Its performance even goes beyond that if you count the fact that this is a wheeled cooler. And this factor might be enough to compensate for the lacking ice retention performance.
The large pair of wheels is better designed than you might think. Despite its heavy duty and clumsy look, the pair of wheels is able to maneuver around smoothly and allows you to transport goods comfortably. However, because the wheels are thick rubber wheels and their frame is made from a combination of aluminum and stainless steel, this cooler is actually quite heavy even before you start putting anything into it.
●▬▬▬▬๑ ๑▬▬▬▬● ●▬▬▬▬๑ ๑▬▬▬▬● ●▬▬▬▬๑ ๑▬▬▬▬●
۞۞۞ Useful Reference: Best Coolers For Camping
Rest assured that among all the coolers, this is the easiest and most comfortable cooler for you to move from one point to another. Otherwise, it would not be worthy of being one of the most expensive coolers on the market. In fact, it is exactly because of this transportation design that the cooler is so pricey. Other comparable wheeled coolers use cheaper materials to make the wheels and the frame, resulting in their lacking durability when compared to this one.
The sturdy design of the wheels and the frame is the main selling point and competitive advantage of this cooler. When you take into consideration that other top models on the market either do not have wheels and only offer you a cheap cart, or have wheels but cannot provide the same level of quality and affordability, then you might appreciate that this cooler manages to achieve much more.
Other than the sturdy design of the wheels and the frame, the build of the cooler itself is also very durable thanks to it being rotomolded. The only downside to this cooler is that it does not have the same storage space that it advertises. But still, given the available space that it has, it is still a lot more spacious than a couple of other top competing coolers on the market.
CONCLUSION
While the price tag of this cooler might shock you at first, as explained above, the price tag of the cooler is actually very reasonable. You will not be able to easily find another model on the market that offers the same level of value while being more affordable than this one. And so, you can say that this cooler model is the Best Coolers In The World for the price.
If you have selected the correct board in the tools tab of the IDE, then it should blink.
I don't have a Mega to try it, but try changing "LED_BUILTIN" to "D13". If this works, then you might not have the right board selected under Tools.
