Arduino Mega 2560 PWM Setting
Hi Everyone, i want to ask about PWM setting on Arduino Mega 2560.
Previously, i use this PWM setting for my Arduino Board that based on ATMEga 328p microcontroller.
TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00);
  TCCR0B = _BV(CS00);
  TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM10);
  TCCR1B = _BV(CS10);
  TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM20);
  TCCR2B = _BV(CS20);
Can i use same PWM setting in Arduino Mega 2560? Or the PWM setting on Arduino Mega 2560 is different?
They won't be identical. You'll have to haul out the datasheet and do some reading.
I have read the datasheet, they looks identical..
mamette:
[quote author=Nick Gammon link=topic=178094.msg1320594#msg1320594 date=1374133292]
[/quote]
Oh, sorry, they looks identical, but when i try with same code, it didn't works well. I must have missed something..
Which one? You seem to be using 3 timers there. Can you post a full sketch that demonstrates this?
Yes, it is same, and it is works now. I forget to change PIN configuration before. This is the code:
  //ATMega 2560 Pin
  pinMode(13, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
  //Atmega 328p Pin
  pinMode(3, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(9, OUTPUT);
#ifdef PWM_8KHZ_FAST
  TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM01)| _BV(WGM10);
  TCCR0B = _BV(CS01);
  TCCR1A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM10);
  TCCR1B = _BV(WGM12) | _BV(CS11);
  TCCR2A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM21)| _BV(WGM20);
  TCCR2B = _BV(CS21);
#endif
#ifdef PWM_32KHZ_PHASE
  TCCR0B = _BV(CS00);
  TCCR1B = _BV(CS10);
  TCCR2B = _BV(CS20);
#endif
#ifdef PWM_4KHZ_PHASE
  TCCR0B = _BV(CS01);
  TCCR1B = _BV(CS11);
  TCCR2B = _BV(CS21);
#endif
  TIMSK1 |= _BV(TOIE1);
  sei();
  // Enable Timer1 Interrupt for Motor Control
  OCR2A = 0;  //11  APIN
  OCR2B = 0;  //D3
  OCR1A = 0;  //D9  CPIN
  OCR1B = 0;  //D10 BPIN
  OCR0A = 0;  //D6
  OCR0B = 0;  //D5
So, solved?
Yes, it solved, Thank You..
