Arduino Mega 2560 R3 and Wireless Shield v2 not working
Hi all,
I am working on a robot that can be controlled by joystick and voice recognition wirelessly. Everything works as expected until I change the arduino board on the receiving end.
Working:
Receiver - Arduino Uno R3, XBee Series 2 module on Arduino Wireless Shield v2 that is stacked on top of Arduino Uno
Transmitter - Arduino Mega 2560 R3, EasyVR Arduino Shield stacked on Mega 2560, XBee Series 2 module on Arduino Wireless Shield v2 stacked on EasyVR Shield
Not Working:
Receiver - Arduino Mega 2560 R3, XBee Series 2 module on Arduino Wireless Shield v2 that is stacked on top of Mega 2560
I have run out of digital pins to use for an LCD display that I am incorporating and hence need to change to Mega 2560.
So far, I have reached at a conclusion that the Mega boards are transmitting properly as I can see that from the LEDs on the Wireless Shield but the problem is that they are not receiving properly. I have tried interchanging the Mega boards but that has not helped. As soon as I put the Arduino Uno back everything works normal.
Any help regarding this issue will be appreciated. Thank you in advance for your time and support.
Links:
Arduino: http://arduino.cc/en/Main/arduinoBoardMega2560
Wireless Shield: http://www.digikey.com/product-detail/en/A000064/1050-1023-ND/2784004
EasyVR Shield: http://www.veear.eu/products/easyvr-arduino-shield/
Which pins are you trying to use to talk to whatever is on the wireless shield? What does your code look like?
PaulS:
As mentioned earlier, it's an Xbee series 2 module on the Sheild. As it's a Sheild, it uses the digital Pins 0 and 1 (tx and rx) pins on the board to communicate.
That depends on the position of the switch on the shield, which you haven't defined. Nor have you posted any code.
PaulS:
The switch is in 'micro' position on both shields. Please find pseudo code below:
#define motorPin1  2
#define motorPin2  3
#define motorPin3  4
#define motorPin4  5
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
  checkDriveMode();
  IF (driveMode == xx) {
      IF Serial.available() {
          Serial.read().......
          // perform actions as required
  else if (driveMode == yy) {
