Hello everyone!
Last few days I’m trying to read signals from 6ch RC-receiver. I used this code for Arduino UNO and it works perfectly:
//This is the full code for RC
//By: Shantanu Sharma
//Date: 23/10/2013.
//contact me at : shantanu.785@gmail.com
#include <PinChangeInt.h>
#include <PinChangeIntConfig.h>
int led = 13;
int ch6_pin=11;
int ch5_pin=10;
int ch4_pin=9;
int ch3_pin=8;
int ch2_pin=7;
int ch1_pin=6;
// global values for all the channels
volatile uint16_t ch6_start=0, ch6_global_count=0;
volatile uint16_t ch5_start=0, ch5_global_count=0;
volatile uint16_t ch4_start=0, ch4_global_count=0;
volatile uint16_t ch3_start=0, ch3_global_count=0;
volatile uint16_t ch2_start=0, ch2_global_count=0;
volatile uint16_t ch1_start=0, ch1_global_count=0;
volatile uint8_t flag=LOW;//global flag
volatile uint8_t ch6_global_flag=LOW;//global flag
volatile uint8_t ch5_global_flag=LOW;//global flag
volatile uint8_t ch4_global_flag=LOW;//global flag
volatile uint8_t ch3_global_flag=LOW;//global flag
volatile uint8_t ch2_global_flag=LOW;//global flag
volatile uint8_t ch1_global_flag=LOW;//global flag
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// ISR for all channels
PCintPort::attachInterrupt(ch6_pin,ch6_count,CHANGE);
PCintPort::attachInterrupt(ch5_pin,ch5_count,CHANGE);
PCintPort::attachInterrupt(ch4_pin,ch4_count,CHANGE);
PCintPort::attachInterrupt(ch3_pin,ch3_count,CHANGE);
PCintPort::attachInterrupt(ch2_pin,ch2_count,CHANGE);
PCintPort::attachInterrupt(ch1_pin,ch1_count,CHANGE);
Serial.println("press the button");
// the loop routine runs over and over again forever:
volatile static uint16_t ch6_static_count;//local count
volatile static uint16_t ch5_static_count;//local count
volatile static uint16_t ch4_static_count;//local count
volatile static uint16_t ch3_static_count;//local count
volatile static uint16_t ch2_static_count;//local count
volatile static uint16_t ch1_static_count;//local count
volatile static uint8_t updateflags;//lcoal flag
volatile static uint8_t ch6_update_flag;//lcoal flag
volatile static uint8_t ch5_update_flag;//lcoal flag
volatile static uint8_t ch4_update_flag;//lcoal flag
volatile static uint8_t ch3_update_flag;//lcoal flag
volatile static uint8_t ch2_update_flag;//lcoal flag
volatile static uint8_t ch1_update_flag;//lcoal flag
if(flag)
noInterrupts();
updateflags=flag;
ch6_update_flag=ch6_global_flag;
ch5_update_flag=ch5_global_flag;
ch4_update_flag=ch4_global_flag;
ch3_update_flag=ch3_global_flag;
ch2_update_flag=ch2_global_flag;
ch1_update_flag=ch1_global_flag;
if(ch6_update_flag)
ch6_static_count=ch6_global_count;
if(ch5_update_flag)
ch5_static_count=ch5_global_count;
if(ch4_update_flag)
ch4_static_count=ch4_global_count;
if(ch3_update_flag)
ch3_static_count=ch3_global_count;
if(ch2_update_flag)
ch2_static_count=ch2_global_count;
if(ch1_update_flag)
ch1_static_count=ch1_global_count;
// Serial.print("ch6: ");
Serial.println(ch6_static_count);
// Serial.print("\t");
// Serial.print("ch5: ");
Serial.println(ch5_static_count);
// Serial.print("ch4: ");
Serial.println(ch4_static_count);
// Serial.print("ch3: ");
Serial.println(ch3_static_count);
// Serial.print("ch2: ");
Serial.println(ch2_static_count);
// Serial.print("ch1: ");
Serial.println(ch1_static_count);
Serial.print("\n");
ch6_global_count=0;
ch6_global_flag=0;
ch6_update_flag=0;
ch5_global_count=0;
ch5_global_flag=0;
ch5_update_flag=0;
ch4_global_count=0;
ch4_global_flag=0;
ch4_update_flag=0;
ch3_global_count=0;
ch3_global_flag=0;
ch3_update_flag=0;
ch2_global_count=0;
ch2_global_flag=0;
ch2_update_flag=0;
ch1_global_count=0;
ch1_global_flag=0;
ch1_update_flag=0;
flag=0;
interrupts();
//use all the ch*_static_count for computation here.
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(200); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(200);
void ch6_count()
//Serial.println(millis());
if(digitalRead(ch6_pin)==HIGH)
ch6_start= micros();
ch6_global_count=(uint16_t)(micros()-ch6_start);
flag=HIGH;
ch6_global_flag=HIGH;
void ch5_count()
if(digitalRead(ch5_pin)==HIGH)
ch5_start= micros();
ch5_global_count=(uint16_t)(micros()-ch5_start);
flag=HIGH;
ch5_global_flag=HIGH;
void ch4_count()
if(digitalRead(ch4_pin)==HIGH)
ch4_start= micros();
ch4_global_count=(uint16_t)(micros()-ch4_start);
flag=HIGH;
ch4_global_flag=HIGH;
void ch3_count()
if(digitalRead(ch3_pin)==HIGH)
ch3_start= micros();
ch3_global_count=(uint16_t)(micros()-ch3_start);
flag=HIGH;
ch3_global_flag=HIGH;
void ch2_count()
if(digitalRead(ch2_pin)==HIGH)
ch2_start= micros();
ch2_global_count=(uint16_t)(micros()-ch2_start);
flag=HIGH;
ch2_global_flag=HIGH;
void ch1_count()
if(digitalRead(ch1_pin)==HIGH)
ch1_start= micros();
ch1_global_count=(uint16_t)(micros()-ch1_start);
flag=HIGH;
ch1_global_flag=HIGH;
But for Mega it doesn’t work: it only prints “Press the button” and doesn’t get impulses from receiver (or doesn’t print the results, but i doubt it).
So the question is: what’s wrong with this code for Mega? “PinChangeInt” library allows interrupts for every pin, as I understood, so I don’t know what causes trouble.
Thank you for you help.
