Hello,
I am using an Arduino MEGA 2560 (version 1.0), operating system Windows 8, which has 1 SDA and 1 SLA pins, and I am trying to connect two temperature sensors (TMP421) which connect through the SDA and SLA pins on the Arduino.
I can get one temperature sensor working with the Arduino and it is reading the correct temperature, but I tried connecting two temperature sensors in parallel using the same SDA and SLA pins, and the output data does not reflect the actual temperature, the value is off by about 5-10 degrees C.
I am wondering what might be causing this and how we can fix this issue to have two temperature sensors running at the same time?
Thank you in advance for your help.
