I am trying to run 22 servos from an Arduino Mega 2560 using input from Processing, and I can’t seem to send any information from Processing to the Arduino. I can send Serial data the other way (Arduino > processing), and my Uno and Nano work both ways with this code, but the Mega doesn’t seem to want to pull from the Serial port.
I have read a lot of forums talking about hooking up 10uf capacitors to the GND & RST on the mega or putting delays after starting the Serial port in the processing code and I have tried every “solution” I can find but none seem to work so I’m thinking there might be a better way to send the serial data that I’m missing.
Here is the test program I m using:
Arduino Code (ignore all the servo attaching & detaching)
#include <Servo.h>
int sD1 = 60;
Servo servoM1;
Servo servoP1;
Servo servoK4;
Servo servoD3;
Servo servoM4;
Servo servoP4;
Servo servoD5;
Servo servoD1;
Servo servoM5;
Servo servoP2;
Servo servoMe5;
Servo servoP5;
Servo servoD4;
Servo servoP3;
Servo servoK3;
Servo servoK5;
Servo servoK2;
Servo servoM3;
Servo servoM2;
Servo servoK1;
Servo servoMe4;
Servo servoD2;
servoM1.attach(22);
servoP1.attach(23);
servoK4.attach(24);
servoD3.attach(25);
servoM4.attach(26);
servoP4.attach(27);
servoD5.attach(28);
servoD1.attach(4); //29
servoM5.attach(30);
servoP2.attach(31);
servoMe5.attach(32);
servoP5.attach(33);
servoD4.attach(50);
servoP3.attach(35);
servoK3.attach(36);
servoK5.attach(37);
servoK2.attach(38);
servoM3.attach(39);
servoM2.attach(40);
servoK1.attach(41);
servoMe4.attach(42);
servoD2.attach(43);
//servoD1.detach();
servoD2.detach();
servoD3.detach();
servoD4.detach();
servoD5.detach();
servoM1.detach();
servoM2.detach();
servoM3.detach();
servoM4.detach();
servoM5.detach();
servoP1.detach();
servoP2.detach();
servoP3.detach();
servoP4.detach();
servoP5.detach();
servoK1.detach();
servoK2.detach();
servoK3.detach();
servoK4.detach();
servoK5.detach();
servoMe4.detach();
servoMe5.detach();
if (Serial.available()>0)
sD1 = Serial.read();
servoD1.write(sD1); //85-15
Processing code (I’m using the controlP5 library to create sliders):
import controlP5.*;
Serial myPort;
ControlP5 cp5;
int D1;
void setup(){
size (800, 800);
String portName = Serial.list()[1];
myPort = new Serial(this, portName, 9600);
cp5 = new ControlP5(this);
cp5.addSlider("D1")
.setPosition(190,20) //x, y
.setSize(50, 250) //width, height
.setRange(15, 85) //slider range, low - high
.setValue(50) //start val
.setColorBackground(color(0, 0, 255)) //top of slider colour
.setColorForeground(color(0, 255, 0)) //bottom colour
.setColorValue(color(255, 255, 255)) //wall colour
.setColorActive(color(255, 0, 0)) //mouse over colour
void draw() {
background(0,0,0);
myPort.write(6);
Thank you!
EDIT: The whole system just started working after leaving it off for about an hour, unfortunately I didn’t change anything, so i don’t have a solution to the problem.
