Sorry that I tried to simplify the code for discussion. The following code is successfully run Mega with 'C' command every 1 second but failed for 100 ms.
#include <Wire.h>
#include <NewPing.h>
#define SONAR_NUM 3 // Number of Sonar
#define MAX_DISTANCE 400 // Maximum distance (in cm) to ping
NewPing sonar[SONAR_NUM] = { // Ultrasonic Sensor Object array
NewPing(13, 12, MAX_DISTANCE),
NewPing(11, 10, MAX_DISTANCE),
NewPing(9, 8, MAX_DISTANCE)
uint8_t i;
char inbyte; // command byte received from Rpi (Serial 1)
String sid; // String of Ultrasonic sensor id
String dist; // String of distance value
String outpackage; // String sent to rpi via Serial 1
String irsensor; // String of ir sensor id
String irstate; // ir sensor state
// unsigned int iteration;
unsigned int duration;
unsigned int distance;
Serial1.begin(115200);
inbyte = ' ';
if (Serial.available() > 0){
inbyte = Serial.read();
if (inbyte == 'C'){
for (i = 0; i < SONAR_NUM; i++){
// delay(10);
sid = String(i + 1);
duration = sonar[i].ping();
distance = (duration/2)*0.0343;
distance = sonar[i].ping_cm();
dist = String(distance);
outpackage = "u"+sid+" "+dist+"\n";
Serial.print(outpackage);
Serial1.print(outpackage);
Serial.print("E\n");
} else if (inbyte == ' '){
// do nothing
Serial.write(inbyte);
// Serial1.write(inbyte);
