Hi all,
I’m having a very strange issue working with the Arduino Mega 2560, the Wireless SD Shield, and a handful of XBEE ZigBee Pro 2 RF Modules. Here’s the low down:
I want the Arduino to save the data package from the XBEEs (21 hex values, converted to HEX by the Arduino naturally) onto the SD card. I’m reading a continuous voltage onto two router transmitters XBEES through a “mothership” XBEE resident on the wireless SD shield. The data from the XB is sent through its own pins 2+3 (DOut and DIn) to Serial1 on the Mega, due to some other issues (which were resolved by sending the data to Serial1).
The strange part happens anywhere from a few seconds into the below code, to nearly 10 seconds into the code, where the data suddenly shifts from correct data format to simply (-1) values. I’ve attached a few text files of what I’m getting out of the SD card.
#include <SD.h> // SD library
File build; //saving directive
int CSpin = 4;
int hardware = 10;
int anPin;
int serialCheck;
int dataArray[] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int i;
int data;
Serial1.begin(9600);
pinMode(hardware,OUTPUT);
SD.begin(CSpin);
build = SD.open("01245.txt", FILE_WRITE);
if(build) {
build.println("\n\nXB Start Simple V3");
build.println("Time(ms)\tSerial Status\tXB Data");
build.close();
serialCheck = 0;
data = 0;
if(Serial1.available() > 0) { // is there serial connection
serialCheck = 1;
while(!data) { // no new data in the form we want (starting with 0x7E)
if(Serial1.read() == 0x7E) { // delimeter - start of good data
for(i=0; i < 21; ++i) {
dataArray[i] = Serial1.read();
data = 1; // finally got new data
if(build) {
build.print(millis());
build.print("\t");
if(serialCheck) {
build.print("Good connection");
else {
build.print("Bad Connection");
build.print("\t");
for(i = 0; i < 21; ++i) {
build.print(dataArray[i]);
build.print("\t");
build.println("");
build.close();
Here is something I have noticed: the transmission seems nearly instant (<1 second) when the data is flowing correctly. When the data starts to be incorrect/corrupted, the transmission time goes to 3-4 seconds between packages. Could this have something to do with the corruption?
I would really appreciate any comments or suggestions to this problem!
XB_SSBU_V3.txt (3.07 KB)
01244.TXT (3.97 KB)
01243.TXT (11.6 KB)
