I am trying to send a list of bytes from Arduino Mega 2560 to Python.
This is the section of Python code receiving the data stream:
def run(self):
print("Opening %s at %u baud" % (self.portname, self.baudrate))
try:
self.ser = serial.Serial(self.portname, self.baudrate, timeout=SER_TIMEOUT, parity=serial.PARITY_ODD)
time.sleep(SER_TIMEOUT*1.2)
self.ser.reset_input_buffer()
except:
self.ser = None
if not self.ser:
print("Can't open port")
self.running = False
while self.running:
s = self.ser.read(size=1)
print(s)
if self.ser:
self.ser.close()
self.ser = None
This is the section of Arduino code writing the bytes to the serial port:
byte data[] = {0, 1, 2, 3, 4, 5, 6, 7, 8};
for (int i=0; i<9; i++) {
Serial.write(data[i]);
Serial.write(0x00);
This gives the output I'm expecting:
b'\x00'
b'\x01'
b'\x02'
b'\x03'
b'\x04'
b'\x05'
b'\x06'
b'\x07'
b'\x08'
If I remove the line in the Arduino code that's adding zero bytes between every value (Serial.write(0x00);
), I get the following output in Python:
b'\x00'
b'@'
b'\xa0'
b'\x04'
b'A'
b'\xd0'
b'\x08'
I don't want to be sending extraneous data but despite hours of looking online and at the code I can't figure out why python is reading the data like this. To my understanding, setting the read size=1 should mean that the data is read one byte at a time. Is python expecting 16-bit values? Is the issue in the way Arduino is transmitting data? Or am I missing something simple?
