I have an Arduino Mega 2560 which does not support Mouse clicks nad Key strokes
Requirement is to utilize atleast 46 Digtial I/O pins to a Hardware.
Also connect to a Computer and do some Mouse movement and clicks on a particular software/page.
Can I use a USB Host Shield V2.0 for this with the Mega 2560 and utilize the above pins ?
If yes, how many Digital I/O pins, PWM pins and Analogue Pins from the Original Arduino Mega 2560 can be utilized once the USB shield is connected on top of the 2560.?
So is there a way to emulate a mouse move and click on a connected PC using Arduino Mega 2560 alone?
Intent is to select certain applications using the D I/Os and as then select something from a specific software using mouse clicks at specific location. This is to be automated.
Hey i had a quick question and I am having trouble using the Arduino mega and the USB host shield. On the the USBcore.h file I modified the code to:
typedef MAX3421e<P53, P49> MAX3421E; // Official Arduinos (UNO, Duemilanove, Mega, 2560, Leonardo, Due etc.), Intel Edison, Intel Galileo 2 or Teensy 2.0 and 3.0 #endif
Then, uploaded the board_qc sketch to check if everything was operating fine, but nothing was working. From there, I started testing a few things and when I modify the code to
typedef MAX3421e<P10, P9> MAX3421E; // Official Arduinos (UNO, Duemilanove, Mega, 2560, Leonardo, Due etc.), Intel Edison, Intel Galileo 2 or Teensy 2.0 and 3.0 #endif
And I upload the board_qc sketch and everything is working good. I don't know, find it strange that when you change the pins to <P10, P9> it works. So my question is if it only works when i change the pins to <P10, P9> and everything is working fine so what pins is the USB host shield actually using for communication with the Arduino mega? Is there any fix?
