Arduino Mega 2560 W5100 Ethernet Shield and SdFat library
Hi Guys,
I am a newbie to Arduino programming. I have plenty of experience with PIC but this is the first time I am playing with Arduino.
I am playing with an Arduino Mega 2560 and an Ethernet shield based on W5100. I could successfully experiment a web server so I know that my Ethernet shield is working fine.
Then I moved to SD card stuff and I am trying to access the SD card on my Ethernet shield with sdfat. But I am getting the following error when I try to execute the SdInfo example.
SdFat version: 20120719
type any character to start
card.init failed
SD errorCode: 0XA
SD errorData: 0X9
I am using the SdInfo example released with the sdfat library.
 * This sketch attempts to initialize an SD card and analyze its structure.
#include <SdFat.h>
 * SD chip select pin.  Common values are:
 * Arduino Ethernet shield, pin 4.
 * SparkFun SD shield, pin 8.
 * Adafruit SD shields and modules, pin 10.
 * Default SD chip select is the SPI SS pin.
const uint8_t SdChipSelect = 4;
Sd2Card card;
SdVolume vol;
// serial output steam
ArduinoOutStream cout(Serial);
// global for card erase size
uint32_t eraseSize;
// store error strings in flash
#define sdErrorMsg(msg) sdErrorMsg_P(PSTR(msg));
void sdErrorMsg_P(const char* str) {
  cout << pgm(str) << endl;
  if (card.errorCode()) {
    cout << pstr("SD errorCode: ");
    cout << hex << int(card.errorCode()) << endl;
    cout << pstr("SD errorData: ");
    cout << int(card.errorData()) << dec << endl;
uint8_t cidDmp() {
  cid_t cid;
  if (!card.readCID(&cid)) {
    sdErrorMsg("readCID failed");
    return false;
  cout << pstr("\nManufacturer ID: ");
  cout << hex << int(cid.mid) << dec << endl;
  cout << pstr("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
  cout << pstr("Product: ");
  for (uint8_t i = 0; i < 5; i++) {
    cout << cid.pnm[i];
  cout << pstr("\nVersion: ");
  cout << int(cid.prv_n) << '.' << int(cid.prv_m) << endl;
  cout << pstr("Serial number: ") << cid.psn << endl;
  cout << pstr("Manufacturing date: ");
  cout << int(cid.mdt_month) << '/';
  cout << (2000 + cid.mdt_year_low + 10 * cid.mdt_year_high) << endl;
  cout << endl;
  return true;
uint8_t csdDmp() {
  csd_t csd;
  uint8_t eraseSingleBlock;
  uint32_t cardSize = card.cardSize();
  if (cardSize == 0 || !card.readCSD(&csd)) {
    sdErrorMsg("readCSD failed");
    return false;
  if (csd.v1.csd_ver == 0) {
    eraseSingleBlock = csd.v1.erase_blk_en;
    eraseSize = (csd.v1.sector_size_high << 1) | csd.v1.sector_size_low;
  } else if (csd.v2.csd_ver == 1) {
    eraseSingleBlock = csd.v2.erase_blk_en;
    eraseSize = (csd.v2.sector_size_high << 1) | csd.v2.sector_size_low;
    cout << pstr("csd version error\n");
    return false;
  eraseSize++;
  cout << pstr("cardSize: ") << cardSize << pstr(" (512 byte blocks)\n");
  cout << pstr("flashEraseSize: ") << int(eraseSize) << pstr(" blocks\n");
  cout << pstr("eraseSingleBlock: ");
  if (eraseSingleBlock) {
    cout << pstr("true\n");
    cout << pstr("false\n");
  return true;
// print partition table
uint8_t partDmp() {
  cache_t *p = vol.cacheClear();
  if (!card.readBlock(0, p->data)) {
      sdErrorMsg("read MBR failed");
      return false;
  cout << pstr("\nSD Partition Table\n");
  cout << pstr("part,boot,type,start,length\n");
  for (uint8_t ip = 1; ip < 5; ip++) {
    part_t *pt = &p->mbr.part[ip - 1];
    cout << int(ip) << ',' << hex << int(pt->boot) << ',' << int(pt->type);
    cout << dec << ',' << pt->firstSector <<',' << pt->totalSectors << endl;
  return true;
void volDmp() {
  cout << pstr("\nVolume is FAT") << int(vol.fatType()) << endl;
  cout << pstr("blocksPerCluster: ") << int(vol.blocksPerCluster()) << endl;
  cout << pstr("clusterCount: ") << vol.clusterCount() << endl;
  cout << pstr("freeClusters: ") << vol.freeClusterCount() << endl;
  cout << pstr("fatStartBlock: ") << vol.fatStartBlock() << endl;
  cout << pstr("fatCount: ") << int(vol.fatCount()) << endl;
  cout << pstr("blocksPerFat: ") << vol.blocksPerFat() << endl;
  cout << pstr("rootDirStart: ") << vol.rootDirStart() << endl;
  cout << pstr("dataStartBlock: ") << vol.dataStartBlock() << endl;
  if (vol.dataStartBlock() % eraseSize) {
    cout << pstr("Data area is not aligned on flash erase boundaries!\n");
    cout << pstr("Download and use formatter from www.sdcard.org/consumer!\n");
  // use uppercase in hex and use 0X base prefix
  cout << uppercase << showbase << endl;
  // pstr stores strings in flash to save RAM
  cout << pstr("SdFat version: ") << SD_FAT_VERSION << endl;
  // read any existing Serial data
  while (Serial.read() >= 0) {}
  cout << pstr("\ntype any character to start\n");
  while (Serial.read() < 0) {}
  uint32_t t = millis();
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  if (!card.init(SPI_HALF_SPEED, SdChipSelect)) {
    sdErrorMsg("\ncard.init failed");
    return;
  t = millis() - t;
  cout << pstr("\ninit time: ") << t << " ms" << endl;
  cout << pstr("\nCard type: ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      cout << pstr("SD1\n");
    case SD_CARD_TYPE_SD2:
      cout << pstr("SD2\n");
    case SD_CARD_TYPE_SDHC:
      cout << pstr("SDHC\n");
    default:
      cout << pstr("Unknown\n");
  if (!cidDmp()) return;
  if (!csdDmp()) return;
  if (!partDmp()) return;
  if (!vol.init(&card)) {
    sdErrorMsg("\nvol.init failed");
    return;
  volDmp();
The only change I did was changing the chip select statement as,
I have formatter the SD card using SDFormatter so I believe my SD card is properly formatted.
Do you have any idea on this error? How do I troubleshoot the problem?
The error occurs in the card identification part of initialization. The command that fails is called ACMD41.
Any chance you are using a MMC card?
This command ACMD41 is not supported by MMC cards and the SdFat and SD.h libraries do not support MMC cards.
Hi Fat16lib,
The card is unbranded and there is a print "MicroSD".
Just curious about one thing. Do MMC and MicroSD be same physically? If so how do I differentiate them?
/Chathuranga
I don't think a MMCmicro card will fit a microSD socket.
I looked at the status and the the reason ACMD41 failed is "com CRC error". This should never happen since CRC is disabled by default for SPI access.
I have seen a similar problem with one card, an Eye-Fi card.
The latest SdFat supports CRC but it slows access.
Try editing SdFatConfig.h and make this change
#define USE_SD_CRC 2
I could successfully execute the same code with a different SD card, So there should be a "difference" in the SD card I was previously using. Investigating.... :roll_eyes:
I do not see where you are disabling the w5100 during all this. Maybe the w5100 SPI is interfering? In your setup() function try this:
  // disable w5100 SPI
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  // rest of your setup
Pulling pin 10 high is worth a try since SdFat does not set pin 10 high on the Mega.
SdFat pulls pin 10 high on 328 boards to avoid problems but it can't do that on the Mega since SS is not pin 10 on the Mega.
It could be that the W5100 overpowers one SD on the SPI bus but not the other SD.
It's a problem with the cards SPI controller if you still get this.
SD errorCode: 0XA
SD errorData: 0X9
