Arduino MEGA 2560 with Neo 6/7 GPS GPRS and SD GPS Tracker build
Hallo, I am new to the forum and also to Arduino.
I would like to build a GPS tracker.
I have some hardware and code samples.
MEGA 2560 , Waveshare NEO 6M/7M GPS , SIM900 GPRS and SD breakout.
I need help on sorting through the code and connections.
Anybody willing to help ?
So, go ahead.
For which you have defined NO requirements.
and connections.
For hardware that you have NOT posted links to.
Forget it.
Sorry about that .
I wanted to see if anybody would be interested before I start uploading anything.
I had an incident where property of mine relocated without my consent.
I need a GPS device that I can SMS and it does the following:
GPS wakes up/Gets a good fix/ Save good fix on SD/ Sends me last good fix via sms/wait 30 minutes/go to sleep again.
I have a Mega 2560
Sim900 GPRS https://www.elecfreaks.com/3275.html
Nondescript SD breakout board ( http://www.communica.co.za/catalog/Details/P3266065504 )
Neo 6M 7M GPS. (http://www.dx.com/p/u-blox-neo-6m-gps-positioning-module-to-serial-ttl-rs232-black-312527#.WcI7RDWxUyU)
The code I have been looking at: ( Track ME - Arduino Project Hub )
Please let me know what you need to see.
Thank you again
Take a look at NeoGPS for the NMEA parsing. See the example NMEASDlog.ino that can help you get started with the logging part.
Since you have a Mega, be sure to use the HardwareSerial ports Serial1, Serial2 or Serial3 for the GPS and GSM. Don't use a software serial library.
Thank you for your time .
I will have a look and get back to you on this.
Thanks again...
