Hello, im trying to read/write IDs with my 250kHz rfids (yes I have writable chips) but I dont know if Im doing things right for the serial connection, I cant seem to get it to work. Im using the RDM6300
I am using the Arduino Mega 2560 with the TX from the rfid reader plugged into the 1 port on the Arduino. My code is
> uint8_t buffer[14];
uint8_t* buffer_at;
uint8_t* buffer_end = buffer + sizeof(buffer);
String checksum;
boolean tagfound = false;
Serial.println("Serial Ready");
Serial1.begin(9600);
Serial.println("RFID Ready");
if (Serial1.available()){
delay(20);
buffer_at = buffer;
while ( buffer_at < buffer_end )
*buffer_at++ = Serial1.read();
tagfound = true;
Serial1.end();
if (tagfound){
buffer_at = buffer;
uint32_t result = 0;
// Skip the preamble
++buffer_at;
// Accumulate the checksum, starting with the first value
uint8_t checksum = rfid_get_next();
// We are looking for 4 more values
int i = 4;
while(i--)
// Grab the next value
uint8_t value = rfid_get_next();
// Add it into the result
result <<= 8;
result |= value;
// Xor it into the checksum
checksum ^= value;
// Pull out the checksum from the data
uint8_t data_checksum = rfid_get_next();
// Print the result
Serial.print("Tag: ");
Serial.print(result);
if ( checksum == data_checksum )
Serial.println(" OK");
Serial.println(" CHECKSUM FAILED");
// We're done processing, so there is no current value
tagfound = false;
uint8_t rfid_get_next(void)
// sscanf needs a 2-byte space to put the result but we
// only need one byte.
uint16_t hexresult;
// Working space to assemble each byte
static char byte_chars[3];
// Pull out one byte from this position in the stream
snprintf(byte_chars,3,"%c%c",buffer_at[0],buffer_at[1]);
sscanf(byte_chars,"%x",&hexresult);
buffer_at += 2;
return static_cast<uint8_t>(hexresult);
I cant seem to get it to work and was hoping I could get some help! Thanks!
