Arduino Mega 2560 with Sparkfun microSD transflash breakout
So I've got my Mega hooked up to the SD breakout according to the SPI layout of:- DO to pin 50
  • DI to pin 51
  • SCK to pin 52
  • CS to pin 53
  • GND to GND
  • VCC to 3.3VWhich lines up exactly with the datasheet of the Mega 2560's SPI pins. I've been trying to run the ReadWrite example in the SD library through it, but each time I never get past initialisation. The serial readout just stops at "Initializing SD card...initialization failed!"
I've seen some other examples using the breakout that use a 10k resistor between DI to VDD and DO to VDD, are those necessary here or is there something obvious I'm missing?
Do you have something to convert the input signals to the SD card to 3.3V levels?
I presume that's the function of the resistors when tied to ground? If so, nothing outside of the stated wiring is currently present.
The SD cards from 3.3V.
Doesn't sound like you are doing that.
Best method is to wire it with a level translater chip.
