Thanks for the reply, I think there is an issue with the Mega 2560 as I switched to my spare Teensey 3.1 & now have the LED's reacting to codes uploaded to it.
I do however now have a slight issue with the code, the LED's are reacting to changed I make in the code regarding the speed, LED amount, timing ect, but I can't seem to get them to rainbow loop across the strip fading/mixing colors rather then stepping them. here is the code:
/* OctoWS2811 Rainbow.ino - Rainbow Shifting Test
http://www.pjrc.com/teensy/td_libs_OctoWS2811.html
Copyright (c) 2013 Paul Stoffregen, PJRC.COM, LLC
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
Required Connections
pin 2: LED Strip #1 OctoWS2811 drives 8 LED Strips.
pin 14: LED strip #2 All 8 are the same length.
pin 7: LED strip #3
pin 8: LED strip #4 A 100 ohm resistor should used
pin 6: LED strip #5 between each Teensy pin and the
pin 20: LED strip #6 wire to the LED strip, to minimize
pin 21: LED strip #7 high frequency ringining & noise.
pin 5: LED strip #8
pin 15 & 16 - Connect together, but do not use
pin 4 - Do not use
pin 3 - Do not use as PWM. Normal use is ok.
pin 1 - Output indicating CPU usage, monitor with an oscilloscope,
logic analyzer or even an LED (brighter = CPU busier)
#include <OctoWS2811.h>
const int ledsPerStrip = 60;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
int rainbowColors[180];
pinMode(1, OUTPUT);
digitalWrite(1, HIGH);
for (int i=0; i<180; i++) {
int hue = i * 2;
int saturation = 100;
int lightness = 50;
// pre-compute the 180 rainbow colors
rainbowColors[i] = makeColor(hue, saturation, lightness);
digitalWrite(1, LOW);
leds.begin();
rainbow(10, 2500);
// phaseShift is the shift between each row. phaseShift=0
// causes all rows to show the same colors moving together.
// phaseShift=180 causes each row to be the opposite colors
// as the previous.
// cycleTime is the number of milliseconds to shift through
// the entire 360 degrees of the color wheel:
// Red -> Orange -> Yellow -> Green -> Blue -> Violet -> Red
void rainbow(int phaseShift, int cycleTime)
int color, x, y, offset, wait;
wait = cycleTime * 1000 / ledsPerStrip;
for (color=0; color < 180; color++) {
for (x=0; x < ledsPerStrip; x++) {
for (y=0; y < 8; y++) {
int index = (color + x + y*phaseShift/2) % 180;
leds.setPixel(x + y*ledsPerStrip, rainbowColors[index]);
leds.show();
delayMicroseconds(wait);
I have attached the pictures of my temporary setup (due to breaking my soldering Iron & only having a 180 ohm resistor rather then a 100ohm.)
Any help with the code or making the rainbow effect would be great!
Thanks Again for your time & help!
