arduino mega 2560 y vb6 no se ven
buenas, tengo varios dias con esto y no encuentro el error,envio datos desde VB6 a la placa arduino mega 2560, y no envia el mensaje
el dato que se envia es un nro. de telefono ejemplo 17864443322
Private Sub Command1_Click()
With MSComm1
If .PortOpen = False Then .PortOpen = True
Dim dataa As String
For i = 1 To Len(txtNumber.Text)
dataa = Mid(txtNumber.Text, i, 1)
.Output = dataa
Next i
End With
MSComm1.PortOpen = False
end sub
' configuracion del puerto
MSComm1.CommPort = 5
MSComm1.Settings = "9600,N,8,1"
MSComm1.EOFEnable = True
MSComm1.InputLen = 1
MSComm1.RThreshold = 4
MSComm1.PortOpen = True
codigo en arduino
char inData[11]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
char incomingByte=0; //Will hold the incoming character from the Serial Port.
char mobilenumber; // Replace xxxxxxxx with the recipient's mobile number
Serial.flush();
Serial1.begin(9600); //GSM
Serial.println("Em comunicacao...");
delay(15000); // give the GSM module time to initialise, locate network etc.
void loop() {//GSM
//If a character comes in from the cellular module...
// he colocado if (Serial1.available() > 0) tambien y nada que trabaja
if (Serial.available() > 0) {
// lee el byte entrante:
if(index < 10) {
inChar = Serial.read(); // Read a character
inData[index] = inChar; // Store it
index++; // Increment where to write next
inData[index] = '\0'; // Null terminate the string
Serial1.println("AT+CMGF=1"); // set SMS mode to text
Serial1.print("AT+CMGS=");
Serial1.print(34,BYTE); // ASCII equivalent of "
Serial1.print(inData);
Serial1.println(34,BYTE); // ASCII equivalent of "
delay(500); // give the module some thinking time
Serial1.print("dime si llego el msg");
Serial1.println(26,BYTE); // ASCII equivalent of Ctrl-Z
delay(10000); // the SMS module needs time to return to OK status
Serial.print("Msg enviada desde vb.net");
do // loop temp just to test sketch
delay(1);
} while (1>0);
que es lo malo que estoy haciendo, gracias por su ayuda
¿Por que no continuas con el hilo?
El otro hilo es cuando trataba de hacerlo manualmente, el cual si funciona, pero en este caso es que trato de hacerlo a traves de una aplicacion, per es no continuo con el hilo,pero tienes alguna idea cual es el error con este hilo?
gracias
Buenas, logre pasar la data de vb6 al arduino, pero resulta que debo darle un reset a la placa arduino mega 2560 para que tome el siguente dato
ejemplo, la primera ves envio este dato 17864443322, lo hace perfecto, pero luego de 2 segundos aproximadamente le doy click de nuevo y lo que toma es el nro. 2 luego otro click y sale 22, luego otro click y sale 322 y asi hasta que aparecen todos.
codigo arduino
la data viene de esta forma
17864443322>
int command=0;
// if we get a valid byte, read analog ins:
if (Serial.available())
command = Serial.read();
if (command == '>')
Serial.print(inData);
command=0;
inData[index] = command; // Store it
gracias
