Hi I am looking for the codes for the Arduino 2560 Mega to complete my project circuit to produce results for the roll & pitch values on the lcd screen, need some pointers & directions for how to create code & the appropriate connection to the arduino 2560 mega itself & to obtain codes to input on the ide
Start by searching for the libraries that support the LCD and gyro hardware you have. The libraries would hopefully have some examples on how to use the hardware. They may also detail any specific pin connections needed. If the LCD and/or gyro hardware uses a standard serial bus like SPI or I2C, then you would use those pins on your MEGA2560 to connect to your hardware.
There may also be various websites that show how to hook up the LCD and gyro hardware that you have.
could you share the website please, need some pointers on the schematic
Which sensor are you using to detect the roll and pitch ?
i am using MPU6050
Start by finding a library to support it and the same goes for the LCD. You can search for libraries in the IDE Library Manager
