Arduino Mega 2650 with 50 pin 2,4in mcufriend display
Dear all,
I have bought an MCUFRIEND display that was advertised to work flawlessly with Arduino Mega 2650. I had no experience with any TFT LCD from MCUFRIEND and I thought how hard can it be to program it also it was less than 10$ so it though this is a very good deal and I have bought it.
On the website it had no specs no nothing but I thought that there will be some code written on it and I could find it on the web… I was so wrong :o >:(
Anyway after few days research on the web I have found and tried some libraries (see attached) and some examples from them.
Once I have found one simple enough i tried different versions for the display but still nothing the display is only powering up and remains white.
this is the code I used:
// UTFT_Textrotation_Demo (C)2014 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the textrotation-functions.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t BigFont;
extern uint8_t SevenSegNumFont;
// Set the pins to the correct ones for your development shield
// Arduino Uno / 2009:
// Standard Arduino Uno/2009 shield : ,A5,A4,A3,A2
// DisplayModule Arduino Uno TFT shield : ,A5,A4,A3,A2
// Arduino Mega:
// Standard Arduino Mega/Due shield : ,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega : ,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(NIC35WS,38,39,40,41);
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(BigFont);
myGLCD.print(“Text rotation”, 0, 0);
myGLCD.setColor(0, 0, 255);
myGLCD.print(“0 degrees”, 0, 16, 0);
myGLCD.print(“90 degrees”, 319, 0, 90);
myGLCD.print(“180 degrees”, 319, 239, 180);
myGLCD.print(“270 degrees”, 0, 239, 270);
myGLCD.setFont(SevenSegNumFont);
myGLCD.setColor(0, 255, 0);
myGLCD.print(“45”, 90, 100, 45);
myGLCD.print(“90”, 200, 50, 90);
myGLCD.print(“180”, 300, 200, 180);
while (true) {};
the UTFT library didn't get uploaded due to the size. I can share anything from it on demand.
I have never seen this Mega2560 shield in 2.4" size.
You have only got 5 resistor packs. So it will have an 8-bit data bus on digital#22-29. Control signals on #38-41
I suggest that you try UTFT_Demo_ 320x240 with this constructor:
// Arduino Mega:
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega      : <display model>,38,39,40,41
UTFT myGLCD(ILI9325D_8,38,39,40,41);
As far as I can see, UTFT does not support any other “common” 8-bit parallel displays.
Life is much simpler with the mcufriend UNO shields. You can read the controller ID and drive them properly.
Please let us know how you got on. If you have a more modern controller, you will just have to guess.
David.
I have tried it but I have the same result.
also I have found a small program which should give me more information about the display but i’m still in the dark.
the code i used: (no idea what is it doing :frowning: except that it should give me information about my device )
// adapted from LCD_ID_Reader from http://misc.ws/lcd_information
// controllers either read as 16-bit or as a sequence of 8-bit values
//-- Arduino UNO or Mega 2560 Plugged as shield
#define LCD_RST A4
#define LCD_CS A3
#define LCD_RS A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_D0 8
#define LCD_D1 9
#define LCD_D2 2
#define LCD_D3 3
#define LCD_D4 4
#define LCD_D5 5
#define LCD_D6 6
#define LCD_D7 7
    while (!Serial) ;
    Serial.println("Read Registers on MCUFRIEND UNO shield");
    Serial.println("controllers either read as single 16-bit");
    Serial.println("e.g. the ID is at readReg(0)");
    Serial.println("or as a sequence of 8-bit values");
    Serial.println("in special locations (first is dummy)");
    Serial.println("");
    lcdInit();
    lcdReset();      //ensures that controller is in default state
//    for (uint16_t i = 0; i < 256; i++) readReg(i, 7, "f.k");
    readReg(0x00, 2, "ID: ILI9320, ILI9325, ILI9335, ...");
    readReg(0x04, 4, "Manufacturer ID");
    readReg(0x09, 5, "Status Register");
    readReg(0x0A, 2, "Get Powsr Mode");
    readReg(0x0C, 2, "Get Pixel Format");
    readReg(0x61, 2, "RDID1 HX8347-G");
    readReg(0x62, 2, "RDID2 HX8347-G");
    readReg(0x63, 2, "RDID3 HX8347-G");
    readReg(0x64, 2, "RDID1 HX8347-A");
    readReg(0x65, 2, "RDID2 HX8347-A");
    readReg(0x66, 2, "RDID3 HX8347-A");
    readReg(0x67, 2, "RDID Himax HX8347-A");
    readReg(0x70, 2, "Panel Himax HX8347-A");
    readReg(0xA1, 5, "RD_DDB SSD1963");
    readReg(0xB0, 2, "RGB Interface Signal Control");
    readReg(0xB4, 2, "Inversion Control");
    readReg(0xB6, 5, "Display Control");
    readReg(0xB7, 2, "Entry Mode Set");
    readReg(0xBF, 6, "ILI9481, HX8357-B");
    readReg(0xC0, 9, "Panel Control");
    readReg(0xC8, 13, "GAMMA");
    readReg(0xCC, 2, "Panel Control");
    readReg(0xD0, 3, "Power Control");
    readReg(0xD2, 5, "NVM Read");
    readReg(0xD3, 4, "ILI9341, ILI9488");
    readReg(0xDA, 2, "RDID1");
    readReg(0xDB, 2, "RDID2");
    readReg(0xDC, 2, "RDID3");
    readReg(0xE0, 16, "GAMMA-P");
    readReg(0xE1, 16, "GAMMA-N");
    readReg(0xEF, 6, "ILI9327");
    readReg(0xF2, 12, "Adjust Control 2");
    readReg(0xF6, 4, "Interface Control");
void printhex(uint8_t val)
    if (val < 0x10) Serial.print("0");
    Serial.print(val, HEX);
void readReg(uint16_t reg, uint8_t n, const char *msg)
    uint8_t val8;
    lcdReset();
    lcdSetWriteDir();
    lcdWriteCommand(0xB0);     //Command Access Protect
    lcdWriteData(0x00);        //looks wrong
    lcdWriteCommand(0xF6);
    lcdWriteData(0x01);
    lcdWriteData(0x01);
    lcdWriteData(0x03);
    lcdWriteCommand(reg);
    Serial.print("reg(0x");
    printhex(reg >> 8);
    printhex(reg);
    Serial.print(")");
    lcdSetReadDir();
    while (n--) {
        val8 = lcdReadData8();
        Serial.print(" ");
        printhex(val8);
    lcdSetWriteDir();
    Serial.print("\t");
    Serial.println(msg);
void lcdInit()
    pinMode(LCD_CS, OUTPUT);
    digitalWrite(LCD_CS, HIGH);
    pinMode(LCD_RS, OUTPUT);
    digitalWrite(LCD_RS, HIGH);
    pinMode(LCD_WR, OUTPUT);
    digitalWrite(LCD_WR, HIGH);
    pinMode(LCD_RD, OUTPUT);
    digitalWrite(LCD_RD, HIGH);
    pinMode(LCD_RST, OUTPUT);
    digitalWrite(LCD_RST, HIGH);
void lcdReset()
    digitalWrite(LCD_RST, LOW);
    delay(2);
    delay(10);             //allow controller to re-start
void lcdWrite8(uint16_t data)
    digitalWrite(LCD_D0, data & 1);
    digitalWrite(LCD_D1, (data & 2) >> 1);
    digitalWrite(LCD_D2, (data & 4) >> 2);
    digitalWrite(LCD_D3, (data & 8) >> 3);
    digitalWrite(LCD_D4, (data & 16) >> 4);
    digitalWrite(LCD_D5, (data & 32) >> 5);
    digitalWrite(LCD_D6, (data & 64) >> 6);
    digitalWrite(LCD_D7, (data & 128) >> 7);
uint16_t lcdRead8()
    uint16_t result = digitalRead(LCD_D7);
    result <<= 1;
    result |= digitalRead(LCD_D6);
    result <<= 1;
    result |= digitalRead(LCD_D5);
    result <<= 1;
    result |= digitalRead(LCD_D4);
    result <<= 1;
    result |= digitalRead(LCD_D3);
    result <<= 1;
    result |= digitalRead(LCD_D2);
    result <<= 1;
    result |= digitalRead(LCD_D1);
    result <<= 1;
    result |= digitalRead(LCD_D0);
    return result;
void lcdSetWriteDir()
    pinMode(LCD_D0, OUTPUT);
    pinMode(LCD_D1, OUTPUT);
    pinMode(LCD_D2, OUTPUT);
    pinMode(LCD_D3, OUTPUT);
    pinMode(LCD_D4, OUTPUT);
    pinMode(LCD_D5, OUTPUT);
    pinMode(LCD_D6, OUTPUT);
    pinMode(LCD_D7, OUTPUT);
void lcdSetReadDir()
    pinMode(LCD_D0, INPUT);
    pinMode(LCD_D1, INPUT);
    pinMode(LCD_D2, INPUT);
    pinMode(LCD_D3, INPUT);
    pinMode(LCD_D4, INPUT);
    pinMode(LCD_D5, INPUT);
    pinMode(LCD_D6, INPUT);
    pinMode(LCD_D7, INPUT);
void lcdWriteData(uint16_t data)
    lcdSetWriteDir();
    digitalWrite(LCD_CS, LOW);
    lcdWrite8(data >> 8);
    digitalWrite(LCD_WR, LOW);
    delayMicroseconds(10);
    lcdWrite8(data);
void lcdWriteCommand(uint16_t command)
    lcdSetWriteDir();
    digitalWrite(LCD_RS, LOW);
    lcdWrite8(command >> 8);
    lcdWrite8(command);
uint8_t lcdReadData8()
    uint8_t result;
    lcdSetReadDir();
    digitalWrite(LCD_RD, LOW);
    result = lcdRead8();
    return result;
uint16_t lcdReadData16()
    uint16_t result;
    result = lcdReadData8() << 8;
    result |= lcdReadData8();
    return result;
void lcdWriteRegister(uint16_t addr, uint16_t data)
    lcdWriteCommand(addr);
    lcdWriteData(data);
and I have the following response: (which I have no clue what is meaning)
reg(0x0000) 04 04	ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 04 04 04 04	Manufacturer ID
reg(0x0009) 05 05 05 05 05	Status Register
reg(0x000A) 06 06	Get Powsr Mode
reg(0x000C) 04 04	Get Pixel Format
reg(0x0061) 65 65	RDID1 HX8347-G
reg(0x0062) 66 66	RDID2 HX8347-G
reg(0x0063) 67 67	RDID3 HX8347-G
reg(0x0064) 64 64	RDID1 HX8347-A
reg(0x0065) 65 65	RDID2 HX8347-A
reg(0x0066) 66 66	RDID3 HX8347-A
reg(0x0067) 67 67	RDID Himax HX8347-A
reg(0x0070) 74 74	Panel Himax HX8347-A
reg(0x00A1) A5 A5 A5 A5 A5	RD_DDB SSD1963
reg(0x00B0) B4 B4	RGB Interface Signal Control
reg(0x00B4) B4 B4	Inversion Control
reg(0x00B6) B6 B6 B6 B6 B6	Display Control
reg(0x00B7) B7 B7	Entry Mode Set
reg(0x00BF) BF BF BF BF BF BF	ILI9481, HX8357-B
reg(0x00C0) 44 44 44 44 44 44 44 44 44	Panel Control
reg(0x00C8) 44 44 44 44 44 44 44 44 44 44 44 44 44	GAMMA
reg(0x00CC) 44 44	Panel Control
reg(0x00D0) 54 54 54	Power Control
reg(0x00D2) 56 56 56 56 56	NVM Read
reg(0x00D3) 57 57 57 57	ILI9341, ILI9488
reg(0x00DA) 56 56	RDID1
reg(0x00DB) 57 57	RDID2
reg(0x00DC) 54 54	RDID3
reg(0x00E0) E4 E4 E4 E4 E4 E4 E4 E4 E4 E4 E4 E4 E4 E4 E4 E4	GAMMA-P
reg(0x00E1) E5 E5 E5 E5 E5 E5 E5 E5 E5 E5 E5 E5 E5 E5 E5 E5	GAMMA-N
reg(0x00EF) EF EF EF EF EF EF	ILI9327
reg(0x00F2) F6 F6 F6 F6 F6 F6 F6 F6 F6 F6 F6 F6	Adjust Control 2
reg(0x00F6) F6 F6 F6 F6	Interface Control
thank you,
Mihai
First obvious thing I see here that is not matching my configuration is the Analogic pins which are not used in my case:
#define LCD_RST A4
#define LCD_CS A3
#define LCD_RS A2
#define LCD_WR A1
#define LCD_RD A0
Your Shield is write-only. The diagnostic sketch only works with readable Shields e.g. the Uno Shield. (It is my sketch anyway)
It would make no difference if you defined the correct pins.
If you install the MCUFRIEND_kbv library from GitHub, you have to make some special edits.
mcufriend_shield.h: #define USE_SPECIAL
mcufriend_special.h: #define USE_MEGA_8BIT_SHIELD
Then force the relevant ID. e.g. tft.begin(0x9341)
Life is much simpler if you had bought the Uno Shield in the first place.
David.
Hello,
some time has passed and i had not too much time to find how this works and I am still in the dark..
in the meantime the MCUFRIEND site has come online but there is not a lot of information.
to be sincere I am not a very advanced user/programmer and I do not really understand how this display works nor do I understand the library.. (well most of it)
can you give me a simple example and the exact library that i need?
