Hi everyone. I’m new to the Arduino (but have programmed lots before) and I have an issue that I can’t seem to fix. I think the answer’s obvious, but I’m not seeing it! The documentation for the Accelstepper.h library isn’t helping me.
I’m using a standard Radio Control transmitter wired to the Arduino. The X/Y positions of one of the sticks are being read by the Arduino and needs to control a stepper motor.
The stepper motor starts at position 0. (Stick X=0, Y=lots, angle = 0). I can get the stepper to track clockwise or anticlockwise to follow the angle of the stick, no problem. The stepper moves from -2048 steps (-180 degrees) to +2048 steps (+180 degrees).
If I move the stick beyond these end points (Stick X=0, Y=-lots) I want the stepper to follow. At the moment, it takes “the long way around”. Which isn’t the result I’m after.
To calculate the “shortest direction” I’m using the following code:
if(buttonState==1){
// read stick x and y positions
int xValue = 510 - analogRead(A4);
int yValue = analogRead(A5) - 513;
// value in radians
float stickAngle = atan2(xValue, yValue);
// value in step units
float stickTarget = stickAngle*2048/3.14159;
// calculate best direction to turn
float stepperCurrentPosition = stepper2.currentPosition();
float difference = stepperCurrentPosition - stickTarget;
if(difference<-2048){
difference = difference + 4096;
if(difference>2048){
difference = difference - 4096;
if(difference<0){
// needs to move clockwise
stepper2.moveTo(stickTarget);
}else{
// needs to move anticlockwise
stepper2.run();
stepper2.moveTo(0);
stepper2.run();
The question:
What commands do I need to use to ensure the step movement to stickTarget is clockwise or anticlockwise?
I don't think I understand your question sufficiently well to offer advice.
You say the motors move (say) CW when you push the stick to the right and (I assume) the distance moved is proportional to how far the stick is pushed (and CCW when you push the stick to the left). From stick full left to stick full right, the motor move through a full 360 degrees.
If I have that right, then I don't follow the rest of it.
The joystick can move around in an X/Y plane. I’m measuring the angle of the stick relative to the Y-axis: it’s between +/-180 degrees. This angle is converted to steps for the stepper motor’s 360 degree rotation (+/-2048 steps).
Within limits, the stepper motor is matching the stick angle - it’s moving to follow the stick. Result!
However, there’s a point at which “common sense” would move the stepper across the -Y axis, but the stepper takes the long route, all the way back through the +Y axis to reach the stick angle.
… is the solution to force the stepper to take the correct route, but I don’t see how, using accelStepper (and the moveTo command) I can force a clockwise or anticlockwise direction of movement.
You need to measure the resistance or voltage from the joysticks and post that with your code. Without knowing that information the code is not going to be much help. If you provide reliable resistance or voltage information for the "stick" , then debugging the code becomes more straightforward. We can't be sure you wired it correctly. I'm sure you understand we need more that a discription of how "think" it is connected. If you post the information requested we don't need you to tell us how it is connected.
Why are there no debug serial print statements in your code ? You should already be doing that before you post here. If you haven't done that, then you need to do it. That will tell what is going on.
Example: suppose the stepper motor is located at -1800 steps. It’s doing the sensible thing to track to the stick target at +1600 steps by going through step 0. What I needed to do was make the stepper think it’s “a turn ahead” at +2296 steps in order for it to cross the -Y axis. And ensure that “fixing the stepper’s location” only occurs for movements across the -Y axis.
