Hi. I use the arduino mega. I am measuring AC Voltage. My electronic component AD536A true rms to dc convertor. Adc input voltage 0-4.098V and very stabil.
Arduino Aref pin connect MCP1541 IC and 4.098 supply very stabil.
I meausring 17.5V arduino measure=17.5V
I meausring 32.1V arduino measure=32.8V
I meausring 48.1V arduino measure=49.9V (non lineer :S)
I meausring 70.7V arduino measure=74.2V
Can you help me??
My code:
* SmoothADCExample.ino
* This example defines A0 & A1 (analog inputs) to be handled by SmoothADC library
* Samples every 50ms for A0
* Samples every 500us for A1
* Every second, the average value from A0 & A1 are sent to serial port
#include <SimpleModbusSlave.h>
#include <SmoothADC.h>
SmoothADC ADC_0; // SmoothADC instance for Pin 0
SmoothADC ADC_1; // SmoothADC instance for Pin 1
unsigned int ADC0Value = 0; // ADC0 final value
unsigned int ADC1Value = 0; // ADC1 final value
unsigned int MemTimeSerial;
float Vout = 0.00;
float Vin = 0.00;
enum
// just add or remove registers and your good to go...
// The first register starts at address 0
ADC0,
ADC1,
ADC2,
ADC3,
ADC4,
ADC5,
LED_STATE,
BUTTON_STATE,
TOTAL_ERRORS,
// leave this one
HOLDING_REGS_SIZE
// total number of registers for function 3 and 16 share the same register array
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
modbus_configure(9600, 1, 2, HOLDING_REGS_SIZE, 0);
//Serial.begin(9600);
analogReference(EXTERNAL);
ADC_1.init(A1, TB_MS, 100); // Init ADC0 attached to A0 with a 50ms acquisition period
if (ADC_1.isDisabled()) { ADC_1.enable(); }
unsigned int tempTime = millis();
ADC_1.serviceADCPin();
delay(10);
delay(10);
if ((tempTime - MemTimeSerial) > 100)
MemTimeSerial = tempTime;
#ifdef DEBUG
ADC_1.dbgInfo();
#endif
ADC0Value = ADC_1.getADCVal();
Vout = (ADC0Value* 4.098) / 1023.00;
Vin = Vout *1065.510838;
//Serial.println(Vin,1);
holdingRegs[TOTAL_ERRORS] = modbus_update(holdingRegs);
holdingRegs[ADC1]=Vin;
holdingRegs[ADC0]=ADC0Value;
Right. Measure the input to the AD536A using a true RMS DMM. Measure the DC output of the AD536A with a DMM. Record the corresponding analogRead() from the Arduino. Post your results in tabular and graphical form.
This could also be a difference in how the meters work or the calibration of the two instruments.
I see where Robin2 is going. How do you know the Arduino ADC is causing the non-linearity? It could be AD536A interface. I would request four data points per line.
Hand measurement at the input
Voltage at the ADC pin
Count reading from the ADC pin
Converted value in the Arduino
I don’t see a 10x factor in the code, but perhaps there is one somewhere. Given there is then the program would output 70.4V for the 80V input is substantially different than the OP. Not to mention inverted. The OP shows the DMM reading lower than ADC, this is the reverse.
What is the accuracy of the meter you are using? Is the accuracy of the meter reading the AC side match
that of the DC side given that you have switched settings and there is 2 orders of magnitude difference in the measurements being taken. I cannot tell if the error is in the ADC, in the meter being used, or in the interface circuit.
Those reading are awfully detailed, given the ADC steps are 4.9mV each. Other than the reading at 200mV input, they are 42 counts per 200mV (the first step is by 9.8-14.7mV or less than 3 bits). What accuracy and resolution are you expecting?
I am sure there are no problems with my friends connections, but even though the value I'm reading is stable, it is not linear, so even if I do a calculation I get an error.
secretagent:
That is not the correct way to check the behaviour. You are assuming that 39 is perfect. But maybe it is marginal and might have been 38 or 40.
You need to do the calculation I showed in Reply #7. And you also need to know what the reference voltage actually is. I just assumed 5v, but maybe it is 4.95 as suggested in Reply #8
Robin2:
…R
Robin
If you read the first post the OP states they are using a MCP1541 precision voltage reference source connected to AREF and in the setup() function they use the line
