Arduino Mega and GPS EM-506
Hi All,
Can someone help me please with my project.
I’m using the TinyGPS library. I want to set one coordinate (Latitude and longitude) that when the GPS reaches to that one coordinate the LED will turn on.
I would be very happy if someone could help me with the code.
Thanks
You haven't posted any code that I can see.
If you expect help, you'll need to post your code.
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F(“DeviceExample.ino”));
Serial.println(F(“A simple demonstration of TinyGPS++ with an attached GPS module”));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F(“by Mikal Hart”));
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F(“No GPS detected: check wiring.”));
while(true);
void displayInfo()
Serial.print(F(“Location: “));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(”,”));
Serial.print(gps.location.lng(), 6);
Serial.print(F(“INVALID”));
Serial.print(F(" Date/Time: “));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F(”/"));
Serial.print(gps.date.day());
Serial.print(F("/"));
Serial.print(gps.date.year());
Serial.print(F(" “));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F(“0”));
Serial.print(gps.time.hour());
Serial.print(F(”:"));
if (gps.time.minute() < 10) Serial.print(F(“0”));
Serial.print(gps.time.minute());
Serial.print(F(":"));
if (gps.time.second() < 10) Serial.print(F(“0”));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F(“0”));
Serial.print(gps.time.centisecond());
How i can change/add the code in order to set one coordinate (Latitude and longitude) that when the GPS reaches to that one coordinate the LED will turn on?
