Thanks for the reply. TELNET uses the Transmission Control Protocol/Internet Protocol (TCP/IP) to connect to a remote system. I understand TELNET will act as Master. Ethernet shield will acts as Slave to communicate. I had searched for Telnet. It is showing lot of terminal software link. Can you share the link of Telnet or ssh Terminal Software so that it will be helpful to me.
Thanks for the reply. I had Planned to use Mega+Ethernet shield(16 boards) with Different IP Address to communicate with my PC Via Switch. PC to Mega+Ethernet shield will be Modbus TCP/IP. To Test the Modbus TCP/IP in the Mega+Ethernet Shield, is there any library for Modbus TCP/IP? If Yes. Kindly share the same. It will be useful. Any Terminal Software which supports Modbus TCP/IP in the PC side.?
Thanks for the Document link. Megaavr mentioned in the Document, i understand that this Modbus Library will support for Mega 2560. Any Terminal Software which supports Modbus TCP/IP in the PC side to test the Modbus library code through Ethernet Shied?
