Arduino Mega + Arduino USB host shield + SD card module doesn't work
Hi, I have a problem with my Arduino:
I have an Arduino Mega (ATmega2560), an Arduino USB Host Shield (Accessories — Arduino Official Store) and an SD Card Module (Micro SD card adapter, Catalex v1.1). So I tried to connect my SD Card Module to the Arduino Mega by using the pins for the SPI comunication (50, 51, 52, 53), then I tried to load an example sketch (File >> Examples >> SD >> cardInfo):
  SD card test
  This example shows how use the utility libraries on which the'
  SD library is based in order to get info about your SD card.
  Very useful for testing a card when you're not sure whether its working or not.
  The circuit:
    SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
 		Pin 4 used here for consistency with other Arduino examples
  created  28 Mar 2011
  by Limor Fried
  modified 9 Apr 2012
  by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 4;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1);
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("Card type:         ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    while (1);
  Serial.print("Clusters:          ");
  Serial.println(volume.clusterCount());
  Serial.print("Blocks x Cluster:  ");
  Serial.println(volume.blocksPerCluster());
  Serial.print("Total Blocks:      ");
  Serial.println(volume.blocksPerCluster() * volume.clusterCount());
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("Volume type is:    FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize /= 2;                           // SD card blocks are always 512 bytes (2 blocks are 1KB)
  Serial.print("Volume size (Kb):  ");
  Serial.println(volumesize);
  Serial.print("Volume size (Mb):  ");
  volumesize /= 1024;
  Serial.print("Volume size (Gb):  ");
  Serial.println((float)volumesize / 1024.0);
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
which shows how to use the SD Card Module (the one called "cardInfo") and it works perfectly (obviously I change the chipSelect pin to 53). Then I tried to connect the Arduino USB Host Shield to the Arduino Mega and the SD Card Module to this (by using the same pins as before) I loaded the example sketch and this time, once I've opened the Serial Monitor, it gave me an error:
Initializing SD card...initialization failed. Things to check:
So I tried to search a solution for my problem on the internet, I visited so many sites, and I thought that the problem was the CS pin: in fact, as I read on the internet, the problem was that the Arduino USB Host Shield change the CS pin on the Arduino Mega. As I read, the Arduino USB Host Shield occupates the pin 10 and it uses it as CS pin. Then I also read that it was possible to connect the CS pin of the SD Card Module to the pin 4 of the USB Host Shield. I tried to do it and I also tried to connect the CS pin of the SD Card Module to each one of the digital pins that are on the USB Host Shield (each time changing the chipSelect pin on the program)
Have you got any solutions? :confused:
Thanks
P.S.
Sorry for my English.
hi,
I have same issue, did you fix it?
Regards
I didn't fix it yet
Regards
