Hello,
@wildbill We use a 16x2 LCD to display if the cable is bad or good but we want to upgrade it to 20x4 LCD, also we want to use an ethernet shield with microSD card. we don`t use an serial connection to the PC.
For the upgrade list we want to implement the following:
-Ethernet shield + microSD card -> also we want to communicate with our tester over ethernet.
-20x4 LCD
-Rotary Encoder for menu surfing
-Hopefully we manage how to work with an centipede shield-> this will help us to get another 64 testing pins
I attached the INO file and for the moment this is the program that we use in order to test the cable.
Every time that we are testing a new or different cable we need to change this variable here.
// --- Pins used for testing ---
int nod[48] = { 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 22, 23, 24, 25, 26, 27,
28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51 };
// --- Pine name definition ---
String nume[]={ "1M","2M","3M","4M","5M","6M","7M","8M","9M","10M","11M","12M","13M","14M","15M","16M","17M","18M","19M","20M","21M","22M","23M","24M",
"1T","2T","3T","4T","5T","6T","7T","8T","9T","10T","11T","12T","13T","14T","15T","16T","17T","18T","19T","20T","21T","22T","23T","24T"};
// --- Definition of connections between pins ---
const int MaxLenNet=5; // pin number of the connection with most pins + 1
String net[][MaxLenNet] = { {"1M","1T"}, {"2M","2T"}, {"3M","3T"}, {"4M","4T"}, {"5M","6M","5T","6T"}, {"7M","7T"}, {"11M","11T"}, {"12M","13M","12T","13T"},
{"14M","14T"},{"15M","15T"},{"16M","16T"},{"17M","17T"}, {"18M","18T"},{"19M","20M","19T","20T"} };
int lennume=sizeof(nume) / sizeof(nume[0]); // Number of pins defined
int lennet=sizeof(net) / sizeof(net[0]); // Number of defined netts
// --- Definire culori conexiune ---
String culnet[]={ "AbS/Alb", "AbS", "Mar/Alb", "Mar", "Ros+R/A", "Gri/Alb", "Ver/Ng", "Ecranaj",
"Ver/Alb", "Ver", "Mov/Alb", "Mov", "Gri", "Neg+N/A" };
Overall it`s a hard project but i thing it will see the light someday.
Thank you for our replay
Paul L.
tester_2.0.ino (6.66 KB)
