Arduino Mega Canbus shield
Hello friends,
I am trying to create a dash board for my ford fiesta. Im using an arduino mega with a \sparkfun canbus shield.
I have used the example sketch to get the can data such as engine temperature, rpm etc. I have noticed I can only display on PID at a time.
Does anyone know how to display more than one PID on the Serial monitor for example. When I try to display more than one PID, the can bus PIDs are displayed all together
Eg:
I would call engine rpm and temperature and would get the following on the serial monitor,
rpm = 1000
rpm = 1000
rpm = 1000
rpm = 1000
temp = 60
temp = 60
temp = 60
temp = 60
rpm = 1000
rpm = 1000
rpm = 1000
rpm = 1000
It switches between the two PIds.
Even though i am calling different ecu requests, the buffer that is printed prints all the information instead of isolating the requests.
Can any one assist.
Here is the code:
#include <Canbus.h>
char UserInput;
int data;
char buffer[456];  //Data will be temporarily stored to this buffer before being written to the file
void setup(){
Serial.println("CAN-Bus Demo");
if(Canbus.init(CANSPEED_500))  /* Initialise MCP2515 CAN controller at the specified speed */
    Serial.println("CAN Init ok");
  } else
    Serial.println("Can't init CAN");
void loop(){
Canbus.ecu_req(ENGINE_RPM, buffer);
 Serial.print("Engine RPM: ");
 Serial.println(buffer);
 Canbus.ecu_req(ENGINE_COOLANT_TEMP, buffer);
 Serial.print("Engine Coolant Temp: ");
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom. :)
Hi Tom, thanks very much.
Appologies it is my first attempt :)
Jeffreykruger:
Appologies it is my first attempt :slight_smile:
Is this a road going vehicle ?
Yes, fully standard road car
