i have a 12v motor, which is connected to 12v power source and there is signal pin on motor (check image) wich activate the motor, and if i connect it with any of 5V pins from arduino( there are 4 of them) or the 3.3v pin the motor works - so it activate
but if i connect with any of digital pins the motor dont work
digitalWrite(PIN,HIGH)
when i measure voltage on digital pin its 4.9v but motor dont start,
ground of arduino and 12v motor is connected together
I connect arduino via usb to pc so its powered from usb
Is the voltage on the GPIO pin 4.9V with or without the motor connected?
Maybe show us your current code so we can see what you are doing and some more details of the motor? Is it Arduino compatible?
If you are using digitalWrite for simple ON/OFF switching, then you must first set the GPIO pin for output with pinMode(pin, OUTPUT). I expect that the signal pin will probably handle a PWM signal to control the motor speed, in which case, using a PWM capable pin with analogWrite(dutycycle), where dutycycle is a value between 0 to 255 might give you more control.
but the strange is how 3.3v pin and 5v pin in arduino mega can start the motor but digitalPIN high cant, in voltmeter i dont notice any differenve between 5v and other digital pins
Indeed and the GPIO pin is not going to supply enough current to drive it. It will require a transistor or FET, or suitable controller board. When using discrete components It will also be necessary to deal with the back EMF. A purpose made controller board should already have that designed in.
I may be wrong (and am sure someone will correct me if so) but I suspect that 'signal' pin expects 12V PWM. Further information regarding what PWM is can be found here:
