I've an Arduino mega, clone one. I can't seem to upload code to it. It's detecting in Windows device manager at COM 9. I've selected Arduino/Genuino Mega or Mega 2560 as board and COM 9 as COM port. I've been able to upload codes before, so bootloader is there. Also When I make USB connection L LED is blinking 4 or 5 times. I shows "Uploading" for what seems like an eternity and finally shows an error.
I've done loop back test using Hype!Terminal by Connecting GND and RESET, and connecting TX and RX pins. It returns whatever I type in the serial window and not showing anything when I disconnect TX and RX line. So CH340G(USB TTL chip) should be okay.
Error Message
Note: I cant post entire error(more than maximum allowed word length)
Please I've posted it in Stack Exchange
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\NEWUSE~1\AppData\Local\Temp\arduino_build_740583/Blink.ino.hex"
avrdude: writing flash (1470 bytes):
Writing | ########avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_ReceiveMessage(): timeout
does not exist or your board is not connected
