I have made a project using arduino uno and the code works perfectly. I realised that i would need more gpio pins so tried to use an arduino mega. but the code is not compiling in this case.
this is the code
#include <Adafruit_Fingerprint.h>
#include <Arduino.h>
#include <EEPROM.h>
int i=0;
int impulsCount=0;
int total_amount=0;
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
SoftwareSerial mySerial(10, 11);
LiquidCrystal_I2C lcd(0x27,16,2);
#else
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
lcd.init();
lcd.backlight();
attachInterrupt(0,incomingImpuls, FALLING);
EEPROM.get(0, total_amount);
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
pinMode(13, OUTPUT);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) {
delay(1);
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
Serial.print(F("Security level: ")); Serial.println(finger.security_level);
Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
finger.getTemplateCount();
if (finger.templateCount == 0) {
Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
else {
Serial.println("Waiting for valid finger...");
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
void incomingImpuls()
impulsCount=impulsCount+1;
i=0;
//lcd.clear();
//lcd.print("processing");
void loop() // run over and over again
getFingerprintID();
delay(50);
i=i+1;
lcd.clear();
lcd.print("The total");
lcd.setCursor(0,1);
lcd.print("balance is ");
lcd.print( EEPROM.get(0, total_amount));
Serial.print("i=");
Serial.print(i);
Serial.print(" Impulses:");
Serial.print(impulsCount);
Serial.print(" Total:");
Serial.println(total_amount);
if (i>=30 and impulsCount==1){
total_amount=total_amount+1;
impulsCount=0;
EEPROM.put(0, total_amount);
lcd.clear();
lcd.print("1 rs inserted");
if (i>=30 and impulsCount==2){
total_amount=total_amount+2;
impulsCount=0;
lcd.clear();
lcd.print("2 rs inserted");
if (i>=30 and impulsCount==5){
total_amount=total_amount+5;
impulsCount=0;
lcd.clear();
lcd.print("5 rs inserted");
if (i>=30 and impulsCount==10){
total_amount=total_amount+10;
impulsCount=0;
lcd.clear();
lcd.print("10 rs inserted");
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
//Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
// Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
//Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
lcd.clear();
lcd.print("DENIED");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
lcd.clear();
digitalWrite(13, HIGH);
lcd.print("Welcome");
delay(1500);
digitalWrite(13, LOW);
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = finger.fingerFastSearch();
// found a match!
