Arduino Mega digital pins output 1.07 volt !
Hey there,
I was developing an Arduino code for controlling several DC motors, which is an easy task.
However, the code didn't work ! For the first moments, I thought I have a logical error and I started to recorrect my code; but afterwards, I realized that all digital pins of Arduino Mega I have don't work !!!
I think the code is as simple as (I mean I erased the old code and downloaded this code for troubleshooting) :
   digitalWrite(30, HIGH);
This code doesn't work, and 1.07 volts appears across the pin 30 and the ground.
I thought maybe this is burned pin, instead, I should use another pin, I used pin 36; the same output appeared.
Ok, maybe this is a complete broken port, I should use pin number 40, the same result !!
The PWM pins work with no problem.
I don't understand anything, and I cannot find the problem !!
Any help, please ?
ok the problem was in
pinMode(30, OUTPUT);
small things make big problems. Thanx anyway.
