Hello, I have been trying to get a digital servo to run as shown in the attached image. When I connect everything and run the code, the servo makes a weak sound but doesn't spin. I am measuring 5V across the output of the linear regulator. Here's a couple things I've checked and have gotten to work all with the same code running in the Arduino (so the code I have is not the issue):
The exact same wiring shown except with a raw 12V input and no regulator (Servo is rated up to 7.2V so I can't continuously run it at 12V)
Same wiring shown but with a voltage regulator adjusted down to 5V (to insure servo runs at 5V - it does)
Plugging servo red lead into +5V on Arduino and black lead into ground on Arduino. I know this is not recommended but the servo did move, though somewhat irregularly.
Connect all GND (-) lines together, using the blue (-) contact row on your breadbord.
Feed the servo with enough current. The Arduino regulated 5V output is not suited to drive motors. Use a battery directly or a voltage regulator rated for the servo current. Voltage regulators often shut down their output when the load (servo) draws too much current - check!
Is it a 9g servo or a full sized? An arduino 5V out will power a 9g servo usually, but if you have a full sized servo probably it won't like it. How many amps can your voltage regulator put out?
You forgot to say what type of servo you are trying to run and what voltage regulator you have. Details matter.
But trying to run any servo from either a 9V battery or the Arduino 5V pin is asking for trouble. Try it with 4 x AA batteries (prefereably NiMH rechargeables) and no regulator.
DrDiettrich:
Hi, I've been powering the servo with a seperate 12V power supply. Without the linear voltage regulator involved, the servo runs no problem. When I introduce the regulator, the servo does not run. I have measured the voltage across the output and it is indeed outputting a voltage. I tried connecting the ground of the power supply to the Arduino ground as well and still no luck.
*Edit - Is it possible the voltage regulator is outputting 5V but shutting down current? Would it not show as 0V?
