this is the full code but now i am only having issue's with the ultrasonic sensor so only that part is in the loop
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <QTRSensors.h>
#include <Servo.h>
#include <Keypad.h>
// Define servo motor pins
#define BASE_SERVO_PIN 46
#define MIDDLE_SERVO_PIN 48
#define END_SERVO_PIN 50
#define mosfetPin 52 // Pin to control MOSFET (possibly for power control)
// Create servo objects
Servo baseServo;
Servo middleServo;
Servo endServo;
// Initial servo angles
int baseAngle = 135; // Base servo initial angle
int middleAngle = 55; // Middle servo initial angle
int endAngle = 0; // End servo initial angle
// Define ultrasonic sensor pins
#define table_trigpin 4
#define table_echopin 3
#define counter_trigpin 31
#define counter_echopin 33
// Define color sensor pins
#define S0 51
#define S1 53
#define S2 45
#define S3 47
#define sensorOut 49
// Bluetooth module pins
const int bluetoothTx = 12; // HC-05 TX pin
const int bluetoothRx = 11; // HC-05 RX pin
// Line sensor pins
int line_Sensor1 = 24;
int line_Sensor2 = 22;
// Motor control pins and speeds
int motor1speed = 9;
int motor2speed = 5;
int motor1pin1 = 10;
int motor1pin2 = 8;
int motor2pin1 = 7;
int motor2pin2 = 6;
// Keypad configuration
const byte ROWS = 4; // Number of rows in keypad
const byte COLS = 3; // Number of columns in keypad
char key; // Variable to store pressed key
// Various state and measurement variables
int Color_State = 0;
int Hamount = 0; // Number of hamburgers
int Pamount = 0; // Number of pizzas
long table_distance = 0;
long counter_distance = 0;
int Turnning_state = 0;
int state = 0;
int Order = 0;
int y = 0;
int Rfrequency = 0; // Red color frequency from sensor
int Gfrequency = 0; // Green color frequency from sensor
int Bfrequency = 0; // Blue color frequency from sensor
// Define different states for the robot
const int waiting_For_order = 0;
const int going_To_costumer = 1;
const int getting_order = 2;
const int going_to_counter = 3;
const int identify_color = 4;
const int getting_food = 5;
const int going_Back_To_Customer = 6;
const int placing_Order = 7;
const int random_place = 8;
// Define food types
const int No_food = 0;
const int Hamburger = 1;
const int Pizza = 2;
int Matan = 0;
int Harel = 0;
// Define color types
const int Red_Color = 1;
const int Blue_Color = 2;
// Define turning directions
const int Left = 1;
const int Right = 2;
// Create an object for QTR sensors
QTRSensors qtr;
const uint8_t SensorCount = 8; // Number of QTR sensors
uint16_t sensorValues[SensorCount]; // Array to hold sensor values
int blue_state = 0; // Bluetooth state
// Create a software serial object for Bluetooth communication
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
// Create an object for the LCD display
LiquidCrystal_I2C lcd(0x27, 16, 2); // LCD I2C address and size
// Define the keymap for the keypad
char keys[ROWS][COLS] = {
{ '1', '2', '3' },
{ '4', '5', '6' },
{ '7', '8', '9' },
{ '*', '0', '#' }
// Connect to the row pinouts of the keypad
byte rowPins[ROWS] = { 38, 36, 34, 32 };
// Connect to the column pinouts of the keypad
byte colPins[COLS] = { 30, 28, 26 };
// Create an object of keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
// Function declarations for motor control and various operations
void motorForward();
void motorRight();
void motorLeft();
void motorStop();
void motorBackward();
void Print_Lcd_Message(char *line1, char *line2, int delay1);
void Intro();
void OrderConfirmation();
void deletingOrder();
void BringingOrder();
void Getting_Order();
void Going_Back_To_Customer();
void Color_Identify();
void Going_To_Random_Place();
// Initialize serial communication for debugging
// Initialize the LCD
lcd.init();
lcd.backlight();
// Initialize color sensor pins
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
// Set frequency scaling to 20% for the color sensor
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
// Initialize motor control pins
pinMode(motor1speed, OUTPUT);
pinMode(motor2speed, OUTPUT);
pinMode(motor1pin1, OUTPUT);
pinMode(motor1pin2, OUTPUT);
pinMode(motor2pin1, OUTPUT);
pinMode(motor2pin2, OUTPUT);
// Configure the QTR sensors
qtr.setTypeAnalog();
qtr.setSensorPins((const uint8_t[]){ A8, A9, A10, A11, A12, A13, A14, A15 }, SensorCount);
qtr.setEmitterPin(2);
// Calibration process
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // Indicate calibration mode with built-in LED
// Calibrate sensors
/*for (uint16_t i = 0; i < 400; i++)
qtr.calibrate();
digitalWrite(LED_BUILTIN, LOW); // Indicate end of calibration mode
// Print calibration minimum values
for (uint8_t i = 0; i < SensorCount; i++) {
Serial.print(qtr.calibrationOn.minimum[i]);
Serial.print(' ');
// Print calibration maximum values
Serial.print(qtr.calibrationOn.maximum[i]);
Serial.print(' ');
// Initialize Bluetooth communication
bluetooth.begin(38400);
// Initialize ultrasonic sensor pins
pinMode(table_trigpin, OUTPUT);
pinMode(table_echopin, INPUT);
pinMode(counter_trigpin, OUTPUT);
pinMode(counter_echopin, INPUT);
// Set up MOSFET pin
pinMode(mosfetPin, OUTPUT);
// Attach servo motors to their respective pins
baseServo.attach(BASE_SERVO_PIN);
middleServo.attach(MIDDLE_SERVO_PIN);
endServo.attach(END_SERVO_PIN);
// Move crane to initial position
moveCrane(baseAngle, middleAngle, endAngle);
int x = 0;
long prevTime = 0;
lcd.clear();
long table_duration = 0;
long counter_duration = 0;
digitalWrite(table_trigpin, LOW);
delayMicroseconds(2);
digitalWrite(table_trigpin, HIGH);
delayMicroseconds(10);
// Measure the duration of the echo
table_duration = pulseIn(table_echopin, HIGH);
// Calculate the distance in cm
table_distance = table_duration * 0.034 / 2;
digitalWrite(counter_trigpin, LOW);
digitalWrite(counter_trigpin, HIGH);
counter_duration = pulseIn(counter_echopin, HIGH);
counter_distance = counter_duration * 0.034 / 2;
Serial.print("table_distance");
Serial.println(table_distance);
Serial.print("counter_distance");
Serial.println(counter_distance);
delay(300);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(table_distance); // Print first line of message
lcd.setCursor(0, 1);
lcd.print(counter_distance); // Print second line of message
// Delay for specified time
delay(300);
// Main state machine to control the robot's actions based on the current state
switch (state)
case waiting_For_order:
lcd.clear();
lcd.print(state); // Display current state on the LCD
Serial.println(blue_state); // Print Bluetooth state to the Serial Monitor
Waiting_For_Order(); // Call function to handle Waiting_For_Order state
case going_To_costumer:
lcd.clear();
lcd.print(table_distance); // Display table distance on the LCD
Going_To_Costumer(); // Call function to handle Going_To_Costumer state
case getting_order:
lcd.clear();
Getting_Order(); // Call function to handle Getting_order state
case going_to_counter:
lcd.clear();
lcd.print(counter_distance); // Display counter distance on the LCD
Going_To_Counter(); // Call function to handle going_to_counter state
case identify_color:
lcd.clear();
Color_Identify(); // Call function to handle Identify_color state
case getting_food:
lcd.clear();
takeOrder();
// Assuming there should be a function call here similar to others
case going_Back_To_Customer:
lcd.clear();
case placing_Order:
lcd.clear();
Placing_Order();
case random_place:
lcd.clear();
// Function to handle the Waiting_For_Order state
void Waiting_For_Order() {
motorStop(); // Stop motors
if (bluetooth.available() > 0) {
blue_state = bluetooth.read(); // Read Bluetooth data
Serial.print("state=");
state = waiting_For_order; // Reset state if no new data is available
if (blue_state == '1') {
state = going_To_costumer; // Change state to Going_To_costumer if '1' is received
// Function to handle the Going_To_Costumer state
void Going_To_Costumer() {
uint16_t position = qtr.readLineBlack(sensorValues); // Read line sensor values
// Determine if the robot is on the line
bool onLine = (sensorValues[2] >= 500 && sensorValues[3] >= 500 && sensorValues[4] >= 500 && sensorValues[5] >= 500 || sensorValues[3] >= 500 && sensorValues[4] >= 500 && sensorValues[5] >= 500);
// Check for black line on the left and right sensors
bool leftBlack = (sensorValues[0] >= 500 && sensorValues[1] >= 500 && sensorValues[2] >= 500 && sensorValues[3] >= 500 || sensorValues[0] >= 500 && sensorValues[1] >= 500 && sensorValues[2] >= 500
|| sensorValues[0] >= 500 && sensorValues[1] >= 500 || sensorValues[0] >= 500 || sensorValues[1] >= 500 || sensorValues[2] >= 500);
bool rightBlack = (sensorValues[4] >= 500 && sensorValues[5] >= 500 && sensorValues[6] >= 500 && sensorValues[7] >= 500 || sensorValues[5] >= 500 && sensorValues[6] >= 500 && sensorValues[7] >= 500
|| sensorValues[6] >= 500 && sensorValues[7] >= 500 || sensorValues[5] >= 500 || sensorValues[6] >= 500 || sensorValues[7] >= 500);
if (table_distance < 13 && table_distance > 3) {
motorStop(); // Stop motors if an obstacle is detected
state = getting_order; // Change state to Getting_order
Serial.println("Obstacle detected, stopping");
if (onLine) {
Serial.println("Moving forward");
motorForward(); // Move forward if on the line
if (leftBlack && !rightBlack) {
Serial.println("Turning right");
motorLeft(); // Turn left if black line is detected on the left
Turnning_state = Right;
} else if (!leftBlack && rightBlack) {
Serial.println("Turning left");
motorRight(); // Turn right if black line is detected on the right
Turnning_state = Left;
} else if (leftBlack && rightBlack) {
Serial.println("Line split or lost");
motorStop(); // Stop if both sides detect black (could indicate a split in the line or an error)
/*else {
if (Turnning_state == Left) {
motorLeft(); // Continue turning left if the last turn was left
if (Turnning_state == Right) {
motorRight(); // Continue turning right if the last turn was right
Serial.println("not seeing anything");
// Function to display messages on the LCD
void Print_Lcd_Message(char *line1, char *line2, int delay1) {
lcd.clear();
lcd.print(line1); // Print first line of message
lcd.print(line2); // Print second line of message
delay(delay1); // Delay for specified time
// Function to delete the order when '' key is pressed
void deletingOrder() {
if (key == '') {
Print_Lcd_Message("deleting the", "order", 0); // Display message on LCD
Order = No_food; // Set order to No_food
// Function to bring the order when '#' key is pressed
void BringingOrder() {
if (key == '#') {
Print_Lcd_Message("bringing the ", "order", 0); // Display message on LCD
state = going_to_counter; // Change state to going_to_counter
// Function to display introduction messages
void Intro() {
Print_Lcd_Message("welcome to our ", "restaurant", 1500); // Display welcome message
Print_Lcd_Message("Exclusive dining", "1 dish per table.", 3000); // Display dining policy
// Function to handle the Getting_Order state
void Getting_Order() {
Serial.println(Order); // Print current order to Serial Monitor
if (y == 0) {
Intro(); // Display introductory messages
y = y + 1;
// Prompt for order selection
Print_Lcd_Message("1 for hamburger", "2 for pizza", 3000);
key = keypad.waitForKey(); // Wait for key press
delay(350);
// Handle order selection and confirmation
if (key == '1') {
Print_Lcd_Message("you Chose 1 ", "Hamburger.", 2000);
Print_Lcd_Message("Confirm with #", "Deny with *", 1500);
if (key == '*') {
Order = No_food; // Set order to No_food if denied
Print_Lcd_Message("hamburger order", "declined", 1500);
if (key == '#') {
Order = Hamburger; // Set order to Hamburger if confirmed
Print_Lcd_Message("confirm the :", "order of 1", 2500);
Print_Lcd_Message("hamburger with #", " or deny with *", 500);
BringingOrder(); // Call BringingOrder function
deletingOrder(); // Call deletingOrder function
if (key == '2') {
Print_Lcd_Message("you Chose 1 pizza . Confirm: #,Deny: *", "Hamburger.", 1500);
Print_Lcd_Message("Confirm with #", "Deny with *", 1000);
if (key == '*') {
Print_Lcd_Message("pizza order", "declined", 1500);
if (key == '#') {
Order = Pizza; // Set order to Pizza if confirmed
Print_Lcd_Message("confirm the", "order of 1", 2500);
Print_Lcd_Message("pizza with #", " or deny with *", 500);
// Function to handle the Going_To_Counter state
void Going_To_Counter() {
if (counter_distance < 13 && counter_distance > 3) {
state = identify_color; // Change state to Identify_color
if (onLine) {
/else {
if (Order == Hamburger) {
Print_Lcd_Message(Hamburger, "", 0);
Serial.println("Hamburger");
} else if (Order == Pizza) {
Print_Lcd_Message(Pizza, "", 0);
Serial.println("pizza");
delay(1000); // Small delay before starting color identification
// Setting red filtered photodiodes to be read
digitalWrite(S2, LOW);
digitalWrite(S3, LOW);
// Reading the output frequency from the sensor
Rfrequency = pulseIn(sensorOut, LOW);
// Remapping the frequency value to the RGB model (0 to 255)
Rfrequency = map(Rfrequency, 250, 10, 255, 0);
Serial.print("R= "); //printing name
Serial.print(Rfrequency); //printing RED color frequency
Serial.println(" ");
// Setting green filtered photodiodes to be read
digitalWrite(S2, HIGH);
digitalWrite(S3, HIGH);
Gfrequency = pulseIn(sensorOut, LOW);
Gfrequency = map(Gfrequency, 300, 90, 255, 0);
Serial.print("G= "); //printing name
Serial.print(Gfrequency); //printing RED color frequency
// Setting blue filtered photodiodes to be read
Bfrequency = pulseIn(sensorOut, LOW);
Bfrequency = map(Bfrequency, 250, 70, 255, 0);
Serial.print("B= "); //printing name
Serial.print(Bfrequency); //printing RED color frequency
// Reading the line sensor values
if (Rfrequency > 15 && Rfrequency < 65 && Gfrequency < -35 && Gfrequency > -90 && Bfrequency < -40 && Bfrequency > -100) {
Harel = 1;
Matan = 0;
Serial.println("seein Green");
if (Rfrequency > 0 && Rfrequency < 50 && Gfrequency < 0 && Gfrequency > -50 && Bfrequency < -50 && Bfrequency > -90) {
Matan = 2;
Harel = 0;
Serial.println("seein red");
// Check if the detected color matches the expected color for the order
if ((Order == Hamburger && Harel == 1) || (Order == Pizza && Matan == 2)) {
motorStop(); // Stop the motors if the food color is detected
state = getting_food; // Change state to Getting_food
Serial.println("spotted the food color, stopping");
Matan = 0;
Harel = 0;
if (onLine) {
motorLeft(); // Turn right if black line is detected on the left
motorLeft(); // Turn left if black line is detected on the right
/*else {
void motorForward() {
// Set motor 1 to move forward
digitalWrite(motor1pin2, HIGH); // Enable motor 1
digitalWrite(motor1pin1, LOW); // Set motor 1 direction forward
analogWrite(motor1speed, 150); // Set motor 1 speed
// Set motor 2 to move forward
digitalWrite(motor2pin2, HIGH); // Enable motor 2
digitalWrite(motor2pin1, LOW); // Set motor 2 direction forward
analogWrite(motor2speed, 150); // Set motor 2 speed
void motorRight() {
analogWrite(motor1speed, 200); // Set motor 1 speed (higher for turning)
// Set motor 2 to stop
digitalWrite(motor2pin2, LOW); // Disable motor 2
digitalWrite(motor2pin1, LOW); // Ensure motor 2 is stopped
analogWrite(motor2speed, 150); // Set motor 2 speed (lower for turning)
void motorLeft() {
// Set motor 1 to stop
digitalWrite(motor1pin2, LOW); // Disable motor 1
digitalWrite(motor1pin1, LOW); // Ensure motor 1 is stopped
analogWrite(motor1speed, 150); // Set motor 1 speed (lower for turning)
analogWrite(motor2speed, 200); // Set motor 2 speed (higher for turning)
void motorStop() {
// Stop motor 1
digitalWrite(motor1pin1, LOW); // Disable motor 1
digitalWrite(motor1pin2, LOW); // Ensure motor 1 is stopped
analogWrite(motor1speed, 0); // Set motor 1 speed to 0
// Stop motor 2
digitalWrite(motor2pin1, LOW); // Disable motor 2
digitalWrite(motor2pin2, LOW); // Ensure motor 2 is stopped
analogWrite(motor2speed, 0); // Set motor 2 speed to 0
void motorBackward() {
// Set motor 1 to move backward
digitalWrite(motor1pin2, LOW); // Disable motor 1 forward direction
digitalWrite(motor1pin1, HIGH); // Enable motor 1 backward direction
// Set motor 2 to move backward
digitalWrite(motor2pin2, LOW); // Disable motor 2 forward direction
digitalWrite(motor2pin1, HIGH); // Enable motor 2 backward direction
void moveCraneDown() {
for (int angle = 55; angle <= 90; angle++) {
middleServo.write(angle); // Move the servo to the current angle
delay(15); // Adjust this delay as needed for the desired speed of rotation
// Rotate the servo from 0 to 180 degrees
for (int angle = 0; angle <= 360; angle++) {
endServo.write(angle); // Move the servo to the current angle
void moveCraneUp() {
for (int angle = 360; angle >= 0; angle--) {
for (int angle = 90; angle >= 55; angle--) {
void moveCraneRight() {
for (int angle = 42; angle <= 180; angle++) {
baseServo.write(angle); // Move the servo to the current angle
void moveCraneLeft() {
for (int angle = 180; angle >= 42; angle--) {
void takeOrder() {
// Move the crane to the left position
moveCraneLeft();
delay(2000); // Delay for 2 seconds
// Move the crane down to pick up the order
moveCraneDown();
digitalWrite(mosfetPin, HIGH); // Activate the MOSFET to pick up the order
// Move the crane back up
moveCraneUp();
state = going_Back_To_Customer;
void moveCrane(int base, int middle, int end) {
// Move the base servo to the specified angle
baseServo.write(base);
// Move the middle servo to the specified angle
middleServo.write(middle);
// Move the end servo to the specified angle
endServo.write(end);
delay(500); // Delay to allow the servos to reach the desired position
void Going_Back_To_Customer() {
state = placing_Order; // Change state to Getting_order
if (onLine) {
/else {
void Placing_Order() {
// Move the crane to the right position
moveCraneRight();
// Move the crane down to place the order
moveCraneDown();
digitalWrite(mosfetPin, LOW); // Deactivate the MOSFET to release the order
moveCraneUp();
state = random_place;
void Going_To_Random_Place() {
unsigned long startTime = millis(); // Get the current time in milliseconds
for (unsigned long elapsedTime = millis() - startTime; elapsedTime < 2000; elapsedTime = millis() - startTime) {
if (onLine) {
/* else {
Order = No_food;
Matan = 0;
Harel = 0;
blue_state = 0;
