I can’t get my program to print temperature on TFT.
#include <DallasTemperature.h>
#include <OneWire.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino’s reset pin
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire ds(22); // on pin 22 (a 4.7K resistor is necessary)
void setup(void) {
tft.reset();
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println(“No more addresses.”);
ds.reset_search();
delay(2500);
return;
Serial.print(“ROM =”);
for( i = 0; i < 8; i++) {
Serial.write(’ ');
Serial.print(addr*, HEX);*
if (OneWire::crc8(addr, 7) != addr[7]) {*
Serial.println(“CRC is not valid!”);*
return;*
Serial.println();*
// the first ROM byte indicates which chip*
switch (addr[0]) {*
case 0x10:*
Serial.println(" Chip = DS18S20"); // or old DS1820*
type_s = 1;*
break;*
case 0x28:*
Serial.println(" Chip = DS18B20");*
type_s = 0;*
break;*
case 0x22:*
Serial.println(" Chip = DS1822");*
type_s = 0;*
break;*
default:*
Serial.println(“Device is not a DS18x20 family device.”);*
return;*
ds.reset();*
ds.select(addr);*
ds.write(0x44, 1); // start conversion, with parasite power on at the end*
delay(2500); // maybe 750ms is enough, maybe not*
// we might do a ds.depower() here, but the reset will take care of it.*
present = ds.reset();*
ds.select(addr); *
ds.write(0xBE); // Read Scratchpad*
Serial.print(" Data = ");*
Serial.print(present, HEX);*
Serial.print(" ");*
for ( i = 0; i < 9; i++) { // we need 9 bytes*
_ data = ds.read();_
_ Serial.print(data*, HEX);
Serial.print(" “);
Serial.print(” CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// Convert the data to actual temperature*
* // because the result is a 16 bit signed integer, it should*
* // be stored to an “int16_t” type, which is always 16 bits*
* // even when compiled on a 32 bit processor._
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
_ raw = raw << 3; // 9 bit resolution default*
* if (data[7] == 0x10) {
// “count remain” gives full 12 bit resolution*
* raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let’s zero them*
* if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms*
* else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms*
* else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms*
* //// default is 12 bit resolution, 750 ms conversion time*
* }*_
* celsius = (float)raw / 16.0;*
_ fahrenheit = celsius * 1.8 + 32.0;
* Serial.print(" Temperature = “);
Serial.print(celsius);
Serial.print(” Celsius, “);
Serial.print(fahrenheit);
Serial.println(” Fahrenheit");
testText();
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(BLACK); tft.setTextSize(3);
tft.println(“1.Temp:”);
tft.setCursor(135, 0);
tft.println(“140”);*_
