Hi everyone. I recently got 2 ethernet shields based on the w5100 chip. They just work instantly and then stop working.
I ping them and sometimes I get <1ms(very few times) other times 100-500ms(most of the times).
when I try the standard web server aplication I can see for a second(if I am veeery lucky) how it displays the spected info in the web page, but then it says unable to carge the web... So then, I try to load the web again but I get nothing. And if i wait some time, may be minutes, it can sometimes work again for a second. And again and again....
I connected the shield directly to the router, and I can make tests with my computer connected to the router by wire or with other computers and laptops connecter by ethernet cable or by wifi.
I can do a lot of test if you want... ![]()
here is the code, It just says for how much ms is the arduino working already:
#include <SPI.h>
#include <Ethernet.h>
// Configuración de direccion MAC e IP.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,13);
// Inicia la libreria Ethernet server con el puerto 80 (por defecto el puerto HTTP).
EthernetServer server(80);
// Inicia el puerto serie.
// Inicia la conexión Ethernet y el servidor.
Ethernet.begin(mac, ip);
server.begin();
Serial.print("IP local del servidor ");
Serial.println(Ethernet.localIP());
EthernetClient client = server.available(); // Escucha a los clientes entrantes.
if (client) { // Si un cliente se conecta al servidor:
Serial.println("Nuevo cliente");
boolean currentLineIsBlank = true; // Marcador para enviar la respuesta desde el servidor.
while (client.connected()) { // Repite mientas existe clientes conectados:
if (client.available()) {
char c = client.read();
Serial.write(c); // Imprime por el puerto serie la petición del cliente (caracter a caracter)
if (c == '\n' && currentLineIsBlank) { // Se envia la respuesta a una petición de un cliente cuando a finalizado la petición:
// Respuesta:
client.println("HTTP/1.1 200 OK"); // Enviar un encabezado de respuesta HTTP estándar
client.println("Content-Type: text/html");
client.println("Connection: close"); // Se cerrará la conexiós despues de enviar la respuesta.
client.println("Refresh: 5"); // Refrescar automáticamente la página después de 5 segundos.
client.println();
client.println("<!DOCTYPE HTML>"); // Tipo de documento.
client.println("<html>"); // Etiqueta html inicio del documento.
client.print("Hola soy Arduino!! - ");
client.print(millis()); // Tiempo de funcionamiento en ms.
client.print("ms encendido. ");
client.println("
"); // Etiqueta html salto de linea.
client.println("</html>"); // Etiqueta html fin del documento.
if (c == '\n') { // Si el caracter es un salto de linea:
currentLineIsBlank = true; // La petición a terminado, se respondera a dicha peticón en el sigueitne ciclo.
else if (c != '\r') { // Si el caracter no es un retorno de carro (la petición no a terminado).
currentLineIsBlank = false; // Seguimos escuchando la petición.
delay(1); // Espera para dar tiempo al navegador a recivir los datos.
client.stop(); // Cierra la conexión.
Serial.println("Cliente desconectado");
