Arduino Mega + Ethernet Shield + Servo library, pin compatibility?
Quick question, and I have searched around for an answer but havent seen anything obvious.
I am getting an Arduino Mega and plan to use my current Ethernet Shield with it in addition to controlling 1-3 servos using the Servo library.
I know the Ethernet Shield uses pins 4 (for sd card), 10, 11, 12, 13.
The Servo library page says that PWM outputs are unaffected unless there are 12+ servos, in which case pins 11 and 12 will have disabled PWM output.
so if I just use 3 servos, there shouldn't be any interference with the Ethernet shield?
