Hello people !
I’m trying to send a value to my slave (arduino uno) via an 1-Wire-to-I2C Master Bridge DS28E17 with 20m of RJ45 cable. The DS28E17 module is well recognised by the master (arduino Mega2560) (using 1Wire scanner showing the correct adress of the DS28E17 module).
But the Slaved UNO is not responding… Even if I using an I2C scanner in local (both arduinos connected together without RJ45 cable), no adress is recognised… Can you help me please??
I’m following already this topic, but nothing is working… (https://forum.arduino.cc/index.php?topic=431939.msg2987174#msg2987174)
The datasheet of the DS28E17 module : https://datasheets.maximintegrated.com/en/ds/DS28E17.pdf
The serial monitor is showing this on the master (nothing on the slave serial monitor):
Status =2
Write Status =255
My code :
Master on Mega
#include <OneWire.h>
#define ONEWIRE_PIN 8
#define DS28E17_ID 0x19,0x41,0xA3,0x02,0x00,0x00,0x00,0x0F
#define WRITE_DATA_WITH_STOP 0x4B
#define I2C_ADDRESS 0x04
OneWire oneWire(ONEWIRE_PIN);
uint8_t address[8];
void printBytes(uint8_t *addr, uint8_t count, bool newline=0)
for (uint8_t i = 0; i < count; i++)
Serial.print(addr[i] >> 4, HEX); //prints the first 4 bits (most left) of addr in Hexadecimal system
Serial.print(addr[i] & 0x0f, HEX); //BitWise between addr e 00001111, allows to print the other 4 bits (on the right)
Serial.print(" ");
if (newline)
bool write(uint8_t i2cAddress, uint8_t i2cData) // Write a single byte to the I2C slave
uint8_t packet[6]; // Reserve bytes to transmit data
packet[0] = WRITE_DATA_WITH_STOP; // Command ("Write Data With Stop")
packet[1] = i2cAddress; // I2C slave to address
packet[2] = 0x01; // Number of data bytes to write
packet[3] = i2cData; // The data to write
uint16_t CRC16 = oneWire.crc16(&packet[0], 4);
CRC16 = ~CRC16;
packet[5] = CRC16 >> 8; // Most significant byte of 16 bit CRC
packet[4] = CRC16 & 0xFF; // Least significant byte of 16 bit CRC
oneWire.reset();
oneWire.select(address);
oneWire.write_bytes(packet, sizeof(packet), 1); //Write the packet and hold the bus
while(oneWire.read_bit() == true) // Wait for not busy
delay(1);
Serial.print(F("Status ="));
Serial.println(oneWire.read());
Serial.print(F("Write Status ="));
oneWire.depower(); // Release the bus
Serial.println(F("Looking for ID"));
if (!oneWire.search(address))
Serial.println(F("No address."));
Serial.println(F("Got this address..."));
printBytes(address, sizeof(address), true);
if (address[0] == DS28E17_ID)
Serial.println(F("Found a DS28E17 I2C Bridge"));
while (1); // Halt if not the right 1 wire device
Serial.print("I2c adress "),Serial.println(I2C_ADDRESS);
write(I2C_ADDRESS, 15); //I2C Address, I2C Data Byte
delay(3000);
Slave on UNO
#include <Wire.h>
void Reception(int data)
//This function triggers when data is sent by Master
Serial.print(F("Data on BUS detected: "));
byte x = Wire.read();
Serial.println(x);
//Slave Code
Wire.begin(4); //Initializing Arduino as Slave with address 0x04h
Wire.onReceive(Reception); //Call the function Reception when data is sent
Serial.println("ready");
