Arduino Mega + Mega sensor Shield + LCD + Midi
Hello,
I gonna use Mega Arduino + Mega senso shield.
I gonna use http://www.emartee.com/product/41872/Arduino-Serial-LCD-1602-Shield for the LCD
And for i want to make a simple PCB using the Tx output.
Is that possible to use a LCD showing strings and sending data over the Midi output. In the code LCD and Midi seems to be coded with the same function :
Serial.begin(31250); // for Midi
Serial.begin(9600); // for LCD
If not what is the simplest solution .
Thanks
DS
You have multiple serial ports on the Mega. Use one of them for the LCD and another one for the Midi data.
But, what does this have to do with wanting to make a PCB?
A word is missing :
And for [u]Midi[/u] i want to make a simple PCB using the Tx output.
And for Midi i want to make a simple PCB using the Tx output.
So? You need permission? OK, I'll give you permission.
You need help? With what?
You have a question? OK. Ask it.
