Hello, I have a trouble with my arduino Mega, the output 9 (digital pin) hold the high level of the output and not change or toggle with blink when in the program I write the instruction digitalWrite LOW, the serial monitor read the pin with high level and when I connected this pin to ground without resistor, change to zero, when I write the instruction analogWrite with value of 200, I read the frequency 30Khz by a short moment and then change to zero, do they think that possible this pin is damage? or maybe is necessary reinstall the bootloader for fix this trouble, thanks
ALEJANDRO31:
All sorts of wrongs in this.
Perhaps you should read a tutorial.
Please post the code you are running, how are you using the serial monitor to read the pin? Use the code tags button, </> in the menu, to add it.
analogWrite will have a frequency of ~ 490 or 980 Hz, where are you getting 30 KHz from?
If you grounded the pin with no resistor while digitalWrite or analogWrite were trying to output a high level, then you more than likely damaged the pin. Does the 2560 chip feel warm or hot to the touch?
If load and run the File:Examples:Basic:Blink program, does the L LED (the onboard LED) still blink?
