Hello,
I am working on communication project. where I used Arduino Mega, 16*2 LCD and NRF sensor. When I check it on the circuit, I am not getting anything. It just read the value detected by ultrasonic sensor.
I am not sure if this code is write or not. Please guide me to solve it. Aim: Nrf is acting as transmitter as well as receiver both in this project.
Transmitter
#include <LiquidCrystal.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define MAX_DISTANCE 400 // Maximum distance (in cm) to ping.
#define CE_PIN 22
#define CSN_PIN 24
LiquidCrystal lcd(8,9,4,5,6,7);
RF24 radio(22, 24); // CE, CSN
const byte addresses[][6] = {"00001", "00002"};
char dataToSendforcollision1[] = "Collision Alert";
char dataToSendforcollision2[] = "Lower the speed!";
char dataToSendforovertake1[] = " Car Overtaking ";
char dataToSendforovertake2[] = "Plan to overtake";
char dataReceived[16]; // this must match dataToSend in the TX
//ultrasonic 1
int echoPin1 =47;
int initPin1 =46;
int distance1 =0;
//ultrasonic 2
int echoPin2 =49;
int initPin2 =48;
int distance2 =0;
//ultrasonic 3
int echoPin3 =44;
int initPin3 =45;
int distance3 =0;
lcd.begin(16,2); // columns, rows. use 16,2 for a 16x2 LCD, etc.
lcd.clear();
lcd.setCursor(0,0); // set cursor to column 0, row 1
lcd.print("Dist(cm): "); // Writing on LCD
pinMode(initPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(initPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(initPin3, OUTPUT);
pinMode(echoPin3, INPUT);
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.openWritingPipe(addresses[1]); // 00002
radio.openReadingPipe(1, addresses[0]); // 00001
radio.setPALevel(RF24_PA_MIN);
distance1 = getDistance(initPin1, echoPin1);
lcd.setCursor(12,0); // set cursor to column 12, row 0 (the first row)
lcd.print("L: "); // change this text to whatever you like. keep it clean.
lcd.setCursor(14,0);
lcd.print(distance1);
delay(10);
distance2 = getDistance(initPin2, echoPin2);
lcd.setCursor(0,1); // set cursor to column 0, row 1 (the first row)
lcd.print("F: "); // change this text to whatever you like. keep it clean.
lcd.setCursor(3,1);
lcd.print(distance2);
delay(10);
distance3 = getDistance(initPin3, echoPin3);
lcd.setCursor(12,1); // set cursor to column 12, row 0 (the first row)
lcd.print("R: "); // change this text to whatever you like. keep it clean.
lcd.setCursor(14,1);
lcd.print(distance3);
delay(10);
send(); // to get things started
getData();
int getDistance (int initPin, int echoPin){
digitalWrite(initPin, HIGH);
delayMicroseconds(10);
digitalWrite(initPin, LOW);
unsigned long pulseTime = pulseIn(echoPin, HIGH);
int distance = pulseTime/58;
return distance;
void send() {
radio.stopListening();
//Front Sensor for Safe distance and collision alert
if(distance1 < 50)
{ radio.write( &dataToSendforcollision1, sizeof(dataToSendforcollision1) );
} else
if( (distance1 >= 50) && (distance1 <= 100) )
{ radio.write( &dataToSendforcollision2, sizeof(dataToSendforcollision2 ) );
//Left Sensor detect the overtaking situation by car
if(distance2 < 30)
{ radio.write( &dataToSendforovertake1, sizeof(dataToSendforovertake1) );
} else
if( (distance2 >=30) && (distance2 <= 60) )
{radio.write( &dataToSendforcollision2, sizeof(dataToSendforcollision2) );
//Right Sensor detect the overtaking situation by car
if(distance3 < 30)
} else
if( (distance3>=50) && (distance3<= 80) )
{ radio.write( &dataToSendforcollision2, sizeof(dataToSendforcollision2) );
//get data ==============
void getData() {
if (radio.available()) {
radio.read(&dataReceived, sizeof(dataReceived));
lcd.clear();
lcd.setCursor(0,0);
lcd.print(dataReceived); // change this text to whatever you like. keep it clean.
Receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 22
#define CSN_PIN 24
//ultrasonic 1
int echoPin1 =47;
int initPin1 =46;
int distance1 =0;
//ultrasonic 2
int echoPin2 =49;
int initPin2 =48;
int distance2 =0;
//ultrasonic 3
int echoPin3 =44;
int initPin3 =45;
int distance3 =0;
void setup(){
lcd.clear();
radio.begin();
radio.openWritingPipe(addresses[0]); // 00001
radio.openReadingPipe(1, addresses[1]); // 00002
void loop(){
delay(10);
lcd.setCursor(3,1);
delay(10);
delay(10);
getData();
send();
// get distance ===========
return distance;
void getData() {
lcd.clear();
lcd.setCursor(0,0);
//send data =============
void send() {
if(distance1 < 50)
} else
if(distance2 < 30)
} else
if(distance3 < 30)
} else
