My friends and I are working on a school project. We are using an Arduino Mega and powering it via a 12V battery through the power source input. After a few minutes of running the program, the Arduino starts to restart the program over and over again. In addition, the Arduino is very hot to the touch. We are using a lot of sensors, two DC motors, and 3 servo motors, all are connected to 5v and GND via a small breadboard strip.
Make a list of all the devices that will be connected to the Mega.
Post the list here.
Provide datasheets or a link to a product webpage for each device.
What battery are you using?
Please do not try and cut and paste images and draw coloured lines between them.
You are lucky you did not fry it. Here are some simple guidelines/rules.
Gil's Crispy Critter Rules, they apply to processor hardware:
Rule #1. A Power Supply the Arduino is NOT!
Rule #2. Never Connect Anything Inductive (motor, speaker) to an Arduino!
Rule #3 Don't connecting or disconnecting wires with power on.
Rule #4 Do not apply power to any pin unless you know what you are doing.
Rule #5 Do not exceed maximum Voltages.
LaryD's Corollary's
Coro #1 when first starting out, add a 220R resistor in series with both Input and Output pins.
Coro #2 buy a DMM (Digital Multi-meter) to measure voltages, currents and resistance. Violating these rules tends to make crispy critters out of Arduinos.
Hint: It is best to keep the wires under 25cm/10" for good performance.
