Arduino Mega Pin Issues in 0017
Hello, my first post here!
I got a Arduino Mega and this is my second problem with it and 0017.
the first problem was with the analogue pins solved here
<<in a link i can't post...>>
but now i have another issue:
When applying LOW to pin 42, both pin 42 and pin 43 are set to LOW
here's the code i ran to test this:
void setup(){
void loop(){
Serial.print("Pin 42 ");
Serial.println(digitalRead(42));
Serial.print("Pin 43 ");
Serial.println(digitalRead(43));
and here are the results when pressing one button at a time:
Pin 42 1
Pin 43 0
Pin 42 1
Pin 43 0
Pin 42 1
Pin 43 0
Pin 42 0
Pin 43 0
Pin 42 0
Pin 43 0
Pin 42 0
Pin 43 0
Pin 42 1
Pin 43 0
Pin 42 1
Pin 43 0
Pin 42 1
Pin 43 0
Pin 42 0
Pin 43 0
Pin 42 0
Pin 43 0
Pin 42 0
Pin 43 0
i switched from pressing pin 43 down for 3 seconds, then to 42 for 3 seconds and so on.
for now i'll just use different pins but, is there a way to fix this (similar to the previously mentioned analogue fix?)
Thanks a bunch!
How're those pins wired up?
i have a wire going from pin 43 to a tactile push button to ground
also, i have a wire going from pin 42 to a different tactile push button to ground
Have you enabled the internal pull-ups for those two pins, or are they 'floating' when the switch is not pressed?
A 'floating' pin will pick up noise and read as a random value unless you use an external pull-up or pull-down resistor or enable the internal pull-up.
Lefty
i'm not exactly sure what that means... can you explain? thanks!
and this might help explain things....
i ran the code:
void setup(){
void loop(){
for (int n =0; n < 53; n++){
Serial.println(digitalRead(n));
Serial.println("holy moly");
delay(5000);
with no buttons attached and got...
1
0
1
1
1
1
0
0
0
0
0
0
0
0
0
0
0
0
1
1
1
1
1
1
1
1
1
1
1
0
0
0
1
0
1
0
1
1
1
0
1
1
1
1
1
1
1
1
1
1
0
0
0
holy moly
which doesn't make sense to me... but maybe this has something to do with what you mentioned!
oh crud~! i forgot the resistor for the button, but how does that explain the 2nd test i ran? (when all the pins were disconnected)
Add the following to the setup portion of your sketch:
pinMode(42, INPUT); // set pin to input
digitalWrite(42, HIGH); // turn on pullup resistors
pinMode(43, INPUT); // set pin to input
digitalWrite(43, HIGH); // turn on pullup resistors
from the reference:
Lefty
wooaah aweeesome!!!! thanks for all your insanely quick responses!!!!
