I'm using this code to run a DFplayer on an arduino mega, and it works perfectly :
DFPlayer - A Mini MP3 Player For Arduino
<https://www.dfrobot.com/index.php?route=product/product&product_id=1121>
This example shows the basic function of library for DFPlayer.
Created 2016-12-07
By [Angelo qiao](Angelo.qiao@dfrobot.com)
GNU Lesser General Public License.
See <http://www.gnu.org/licenses/> for details.
All above must be included in any redistribution
/***********Notice and Trouble shooting***************
1.Connection and Diagram can be found here
<https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#Connection_Diagram>
2.This code is tested on Arduino Uno, Leonardo, Mega boards.
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
mySoftwareSerial.begin(9600);
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(10); //Set volume value. From 0 to 30
myDFPlayer.play(1); //Play the first mp3
static unsigned long timer = millis();
if (millis() - timer > 3000) {
timer = millis();
myDFPlayer.next(); //Play next mp3 every 3 second.
if (myDFPlayer.available()) {
printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
However, I need to wire it on other pins than 10 and 11, because I need those pins for fading LEDs. When I try 14 and 15 the player doesn't initialize, despite those pins being software serial compatible.
Any idea why ?
