Arduino Mega pms3003, bme280 and w5100
I use ethernet shield mounted on Arduino mega 2560. I connected BME280. Everything works great. When I connect pms3003 with KAmodLVC there is no data from this sensor. I tried to connect rx and tx to all pins marked as rx and tx on Mega and ethernet shield.
If I connect pms3003 to Arduino Uno it works correct.
This is my code:
#include <BME280I2C.h>
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <Dns.h>
#include <MySQL_Cursor.h>
#include <Wire.h>
#include <EnvironmentCalculations.h>
#include <stdio.h>
#include <PMS.h>
#define N 23
BME280I2C bme;
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char t[8] = "";
char hostname[] = "0000000"; // change to your server's hostname/URL
char user[] = "00000000";               // MySQL user login username
char password[] = "0000000";         // MySQL user login password
char INSERT_DATA[] = "INSERT INTO base.ruchLog (ruch1, hum, pres) VALUES (%s,%s,%s)";
char query[128];
char temperature[10];
char wilgotnosc[10];
char cisnienie[10];
//PMS
char linia1[16], linia2[16];
String sumPM25, sumPM10;
unsigned char bufor [N];
int PM25 = 10, PM10 = 10;
int wartoscPM25(unsigned char *thebuf);
int wartoscPM10(unsigned char *thebuf);
char sprawdzLancuch(unsigned char *thebuf, char leng);
IPAddress server_ip;
EthernetClient client;
MySQL_Connection conn((Client *)&client);
DNSClient dns_client;   // DNS instance
  //while (!Serial); // wait for serial port to connect
  Wire.begin();
  //delay(1000);
    // Nadawanie MAC
   Ethernet.begin(mac_addr);
   Serial.println(Ethernet.localIP());
  // Begin DNS lookup
  dns_client.begin(Ethernet.dnsServerIP());
  dns_client.getHostByName(hostname, server_ip);
  Serial.println(server_ip);
  // End DNS lookup
  if(!bme.begin()) {
      Serial.println("Could not find the BME280 Sensor, check wiring");
      while (1);
    // bme.chipID(); // Deprecated. See chipModel().
  switch(bme.chipModel())
     case BME280::ChipModel_BME280:
       Serial.println("Found BME280 sensor! Success.");
     case BME280::ChipModel_BMP280:
       Serial.println("Found BMP280 sensor! No Humidity available.");
     default:
       Serial.println("Found UNKNOWN sensor! Error!");
  connecting();
void connecting(){
Serial.println("Connecting...");
  if (conn.connect(server_ip, 3306, user, password)) {
  else{
    Serial.println("Not Connected.");
    conn.close();
  printBME280Data(&Serial);
   //delay(500);
void printBME280Data
   Stream* client
   float temp(NAN), hum(NAN), pres(NAN), tempAVG, humAVG, presAVG;
   BME280::TempUnit tempUnit(BME280::TempUnit_Celsius);
   BME280::PresUnit presUnit(BME280::PresUnit_hPa);
   tempAVG=0; humAVG=0;presAVG=0;sumPM25="";sumPM10="";
   for (int a=0; a<10; a++) //co 10 minut zapis do mysql
  bme.read(pres, temp, hum, tempUnit, presUnit);
   client->print("Temperatura: ");
   client->print(temp);
   client->print("°"+ String(tempUnit == BME280::TempUnit_Celsius ? 'C' :'F'));
   client->print("\t\tWilgotność: ");
   client->print(hum);
   client->print("% RH");
   client->print("\t\tCiśnienie: ");
   client->print(pres);
   client->println(" hPa\t\t");
   tempAVG+=temp;
   humAVG+=hum;
   presAVG+=pres;
   //for (int b=0; b<12; b++) // co 5 sekund sprawdzenie czujnika
      if(Serial.find(0x42))
    Serial.readBytes(bufor,N);
     if(bufor[0] == 0x4d){
      if(sprawdzLancuch(bufor,N)){
        PM25=wartoscPM25(bufor);
        PM10=wartoscPM10(bufor);
   sprintf(linia1,"%d",PM25);
   Serial.print(linia1);
   sprintf(linia2,"%d",PM10);
   Serial.println(linia2);
   //Serial.println(sumPM25=sumPM25 + "|" + linia1);
   //Serial.println(sumPM10=sumPM10 + "|" + linia2);
   //delay(5000);
   delay(60000);
    MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
    // Save
    dtostrf(tempAVG/10, 1, 3, temperature);
    dtostrf(humAVG/10, 1, 3, wilgotnosc);
    dtostrf(presAVG/10, 1, 2, cisnienie);
    sprintf(query, INSERT_DATA, temperature, wilgotnosc, cisnienie);
    // Execute the query
    cur_mem->execute(query);
    // Note: since there are no results, we do not need to read any data
    // Deleting the cursor also frees up memory used
    delete cur_mem;
    Serial.println("Dane zapisane.");
  //delay(300000);
int wartoscPM25(unsigned char *buf) // generacja wartosci PM2,5
  int PM25v;
  PM25v=((buf[11]<<8) + buf[12]);
  return PM25v;
int wartoscPM10(unsigned char *buf) // generacja wartosci PM10
  int PM10v;
  PM10v=((buf[13]<<8) + buf[14]);
  return PM10v;
bool sprawdzLancuch(unsigned char *buf, int dlugosc) // sprawdzenie poprawności lancucha
  bool flaga=0;
  int suma=0;
  for(int i=0; i<(dlugosc-2); i++){
  suma+=buf[i];
 suma=suma + 0x42;
  if(suma == ((buf[dlugosc-2]<<8)+buf[dlugosc-1]))
    suma = 0;
    flaga = 1;
  return flaga;
I dont know where I should connect RX and TX cables to start get data from PMS. BME280 is connected to 20 and 21. I checked these pins too.
This code works with Uno but dont works with Mega. Why?
#include <stdio.h>
#include <PMS.h>
#define N 23
int a=0;
void setup(){
void loop(){
   Serial.println(a++);
   if (a==10){sumPM25="";sumPM10="";a=0;}
  int PM25v;
  return PM25v;
  int PM10v;
  return PM10v;
  bool flaga=0;
  int suma=0;
  suma+=buf[i];
 suma=suma + 0x42;
    suma = 0;
    flaga = 1;
  return flaga;
It does not work
sotb:
Didn't look at anything else in your post, but never connect anything to the TX/RX pins of a Mega.
Use one of the OTHER THREE hardware serial pairs of the Mega (pin14-19).
Leo..
It is very precious information for me. You pointed me I schould focus my brain to find what is the name of other three serials. So I read some other examples and understand I need to add line:
Serial2.begin(9600); //in void setup
and change Serial to Serial2:
void loop(){
  if(Serial2.find(0x42))
    Serial2.readBytes(bufor,N);
So you helped me to find solution for Arduino MEGA. Thank you.
Similar situation I have with D1 R2 ESP8266 32M board. Data is coming about 30 seconds, and later data is allways the same as the last and nothing changes. But I have only one serial TX/RX on this board.
I decided to use SoftwareSerial on D2 and D3 pins and it works, but values given by PMS3003 are to high I think. 38 for PM2,5 and 46 for PM10 in my room. Unbelievable.
